R56 bixenon retrofit rotational adjustment
Old Jun 7, 2015 | 10:22 PM
ericf1993's Avatar
ericf1993
hi everyone im new to this site, ive already introduced myself in the 1st gear section. anyways i have the 25w retrofit xenon headlights w/o auto level and washer in my 2012 r56 and i noticed the passenger side projector is rotated a little to the right, is there a way to adjust the rotation of it so its level with the driver side? i know there is an up and down adjuster but i could not find another adjuster on the lights. thanks!
Old Jun 8, 2015 | 07:48 AM
Welcome.
https://www.northamericanmotoring.co...fit-kit-6.html
Linked above. Thanks
Old Jun 9, 2015 | 10:52 AM
ericf1993's Avatar
ericf1993
is there any way to adjust the rotation though? it seems rotate a little clockwise..
Old Jun 9, 2015 | 10:58 AM
From those 4 mounts to the under-hood. They adjust in/ out with the threaded nut. Then you can adjust rotation to the left and right with the placement of the compressed tabs/ bolt adjustment that is on the thread part. As for rotation it can be the placement of those tightening down bolts in reference to the thread bolt hole. Not much maybe a couple mm.
Old Jun 9, 2015 | 11:52 AM
ericf1993's Avatar
ericf1993
So the 4 bolts that hold the headlight in can be loosened and then I have some wiggle room to adjust the rotation a little right?
Old Jun 9, 2015 | 01:12 PM
Yea, just the bolts with that tab holder. Undo all four and wiggle a bit . The top tab that is flat you have to watch as it cannot be twisted that much.
vetsvette
Oct 11, 2015 06:05 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
