R56 Engine error code P0014?
Old Jun 6, 2015 | 09:07 AM
proscia116's Avatar
proscia116
I've tried numerous things to set the engine straight and fix the code.
The motor is sluggish and has barely any power to keep up with highway driving. Could it be one of the VANOS solenoids? If so, how do i test which one is faulty?
I have a 2007 mini cooper non s with the n12 motor. it has 53000 miles on it and im hoping that it's nothing to serious...
Old Jun 8, 2015 | 06:20 AM
grussell's Avatar
grussell
P0014 refers to VVT(variable valve timing) or VCT(variable camshaft timing). This would be for your exhaust side, or front cam. Usually this results in hard starting, poor idle or stalling.
You could try removing the exhaust vanos selenoid and checking if it is gunked up and cleaning it with brake cleaner. I have seen a few post where replacement solved the problem.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
David.R53
Sep 1, 2015 06:49 PM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
PSIChocolate
Aug 13, 2015 12:46 PM
