::ECS Tuning :: Turbo Oil Lines kits | New * Rennline ALU Skid Plates Gen 1 & Gen 2
Old Jun 4, 2015 | 03:21 PM
MINI R58 R59 Turbo Oil Line Kit
Turbochargers operate at speeds at over over 100,000 rpms. The lubrication requirements for this type of system are understandably highly specific and critical to observe carefully.
The MINI R58/R59 feed & return oil lines have a tendency to weaken due primarily to heat exposure, making oil delivery precarious, compromising overall engine hea
The Genuine MINI Turbo Oil Line Kit includes both new return and feed oil lines, as well as a heat resistant plate that installs on the new oil pipe for protection from further damage.
Each kit also includes all installation hardware.
Lubricious
Fits:
R58 MINI Coupe' / S / JCW (2012+)
R59 MINI Roadster / S / JCW (2012+)
Click HERE for oil line kit
MINI R60/R61 Turbo Oil Line Kit
The MINI R60/R61 feed & return oil lines have a tendency to weaken due primarily to heat exposure, making oil delivery precarious, compromising overall engine health.
Lubricious
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE For oil line kits
MINI R58 Coupe & R59 Roadster Expansion Tanks
ECS is now offering a full kit expansion tank replacements for the MINI R58/R59.
Available are ECS-assembled and Genuine MINI replacement options.
The Forge polished alloy tank is a direct-fit replacement for the factory unit, and completely resists the cracking and fading of the original part.
The alloy coolant tank also adds a high-performance, premium look to your engine bay.
Each kit includes a new coolant expansion tank, tank cap, grommet, and torx bolt.
Expand Your Limits
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE For expansion tank kits
MINI R60/R61 Genuine Xenon Headlight Kit
The headlight design of the MINI Cooper defines the car's character more so than any other feature.
ECS is now offering stunning Bi-Xenon headlights for the MINI Countryman and Paceman.
The genuine MINI kit includes left and right side headlights, and retains the factory clear turn signals.
NOTE: Additional coding will need to be done by a MINI dealership for strobe light elimination on startup.
A Clear Improvement
Fits:
R60 MINI Countryman /S/ SX(ALL4)/JCW (2011+)
*Vehicle will need programmed by dealership to activate headlights after install.
Click HERE For Genuine Xenon Headlight Kit
MINI R50/R52/R53 Rennline Aluminum Skid Plate
Known world-wide primarily for their creative and original Porsche offerings, Rennline Inc. is not only the distributor, but manufacturer of the majority of products that wear the Rennline name.
Speed bumps, potholes, and the occasional “off-track” excursion can cause serious damage to critical undercarriage components. The Rennline Alumuinum Skidplate is the best designed solution to the problem.
While this gorgeous addition is rarely seen by onlookers, the peace of mind that comes with this expertly-engineered measure of protection brings more than enough satisfaction.
Don't Go Belly-Up
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Manual Transmissions Only
Click HERE For rennline skid plates
R55-R59 MINI JCW GEOMET® Coated Rotors
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish.
This innovative treatment has been shown to fight rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET® rotors to outperform and outlast stock rotors, and look great behind your MINI JCW's wheels.
Stopping Never Looked So Good!
Fits: Factory JCWs
R56 MINI Cooper JCW (2009-2013)
R55 MINI Clubman JCW (2009-2014)
R57 MINI Cooper Convertible JCW (2009+)
R58 MINI Coupe' JCW (2012+)
R59 MINI Roadster JCW (2012+)
Click HERE For Geomet rotors
MINI R55 R57 Turbo Oil Line Kits
The MINI R55/R57 feed & return oil lines have a tendency to weaken due primarily to heat exposure, making oil delivery precarious, compromising overall engine hea
Lubricious
Fits:
R55 MINI Clubman S/JCW (2008-2014)
R57 MINI Cooper Convertible S/JCW (2009+)
Click HERE For Turbo lines
MINI Gen2 Rennline Aluminum Skid Plate
Protect Your Vitals
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008-2014)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe'/S/JCW (2012+)
*manual transmissions
Click HERE For Rennline
MINI R55/R56/R57 Coolant Expansion Tanks
ECS is now offering a full kit expansion tank replacements for the MINI R55/R56/R57.
Expand Your Limits
Fits:
R55 MINI Clubman / S/ JCW (2008-2014)
R56 MINI Cooper / S/ JCW (2007-2013)
R57 MINI Cooper Convertible / S/ JCW (2009+)
Click HERE For cooling kits
MINI R53/R52 Thermostat Replacement Kits
If you're looking to replace your thermostat don't forget to also replace your hardware. Replacing your cooling system components will ensure your MINI has a long life.
Avoid headaches altogether and replace all problematic items at once to keep your cooling system running efficiently.
Expand Your Limits
Keep Your Cool
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S/ JCW (2005-2008)
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
