Interior/Exterior 2006 R53 oem xenon to led conversion?
The new led kits are just as bright as hid kits. They have ballasts just like hid kits do.
https://goo.gl/t4L6If
This bulb has an LED emitter pointing in one direction, and I'm very skeptical that it will perform well in a projector housing that was designed for a xenon bulb with 360º spread. Let us know how it works out.
have you looked inside a projector housing? there is a cutoff that will not allow for a full 360 degree beam. this is only one design and not necessarily specific to this install. I have used led kits in projector housings without issue. my question was pointed toward the wiring end of this install since the mini has a thin harness.
thanks for your constructive feedback though.
blackie
Oct 2, 2015 07:41 PM
