Car goes one side
Old May 8, 2015 | 02:35 AM
angelinasoul's Avatar
angelinasoul
Car goes one side
Hi guys, I have just replaced my control arm bush. However, the car goes to right on straight road when I didn't hold the steering... My mechanic adjusted the alignment but it still the same. Any clue?
Old May 8, 2015 | 01:28 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Lots of possible reasons-
http://www.aa1car.com/library/steerpul.htm
http://www.agcoauto.com/content/news/p2_articleid/307
You need to check your tires- air pressures all even, uneven wear, problems with the wheels and balance.
Sometimes swapping wheels from front to back can make the pull better or worse.
Old May 8, 2015 | 01:39 PM
grussell's Avatar
grussell
Did he check and/or replace the ball joints and sway bar links? Do you have the print out of the alignment specs?
Getrieben
Sep 12, 2024 07:03 AM
cm.d
Aug 19, 2015 08:51 AM
Minibeagle
Aug 13, 2015 10:00 AM
CM2011RG
Aug 5, 2015 02:00 PM
