R56 A Wheel Conundrum
Old May 4, 2015 | 09:58 AM
BirdofPrey's Avatar
BirdofPrey
A Wheel Conundrum
Do smaller rim sizes make for a smoother ride usually? Assuming they have all-season tires and not performance tires.
Old May 5, 2015 | 08:11 AM
NB Cooper's Avatar
NB Cooper
Maintaining the circumference of the stock tires is important to maintain the accuracy of your speedometer as well as optimizing the stock gearing. However, if you find the ride quality too harsh as many do, you can install smaller diameter rims with higher profile tires (maintaining stock circumference) to reduce the harshness a bit but that comes hand in hand with a reduction in the handling precision. You will only achieve so much as the shocks and springs are tuned for a sporty ride but I did find the rid eof the 16 inch rims better that the 17 inch S rims and Waayyy better than my 19 inch Konigs which were just silly.
I hope this helps.
Old May 5, 2015 | 09:01 AM
kyoo's Avatar
kyoo
yes
Old May 5, 2015 | 02:25 PM
iclancy82's Avatar
iclancy82
Not to state the obvious but, I will. If you currently have run-flat tires, chuck-'em!! They destroy ride quality.
Old May 5, 2015 | 02:32 PM
Iain25's Avatar
Iain25
Yes a smaller rim with the recommended tire size to match on the car will increase ride quality because there is more tire to absorb the impacts. Also, usually a smaller rim is lighter and lends to less unsprung weight which allows the suspension to be more effective. But as mentioned above RFT's will adversely affect ride quality no matter what because the design of the tire has a stiffer sidewall to maintain rigidity when there is no air in the tire, this in turn reduces the shock absorbing effect you would get from a conventional tire.
Old May 5, 2015 | 04:07 PM
mbwicz's Avatar
mbwicz
You need to understand which brakes are on your car, they will limit how small you can go. A base cooper will handle 15" wheels, a S requires a 16" wheel, and factory JCW cars require a 17" wheel.
On my S, I had 16" runflat snows and 17" non-runflat all seasons. The ride quality was similar between the two, just for a comparison.
I agree with the above comments, runflat tires are harsher than non-runflats, and generally smaller wheels will give a more compliant ride.
Have fun,
Mike
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
