:: ECS Tuning :: Gen2 Valve Covers ** ECS X Drilled / Slotted Rotors ** New Wheels
Old Apr 24, 2015 | 01:22 PM
MINI Gen2 R55-R59 N14 Valve Cover
A damaged valve cover can cause oil leaks, vacuum leaks, driveability problems, and a check engine light. Additionally, cracks and warping can result in a significant vacuum leak and result in very poor performance.
The MINI Gen2 R55-R59 N14 valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option - ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Included in the kit are all necessary parts for a professional-level installation - a new valve cover gasket, valve cover seals for the spark plug tubes, and Oil cap & seal.
Got you Covered
Fits: N14 Engine
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE for Valve cover kits
MINI Gen2 R55-R57 N12 Valve Cover
The MINI Gen2 R55-R5 N1valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option - ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Got You Covered
Fits: N12 Engine
R56 MINI Cooper (2007-2010)
R55 MINI Clubman (2008-2010)
R57 MINI Cooper Convertible (2009-2010)
Click HERE Valve cover Kits
R60 R61 MINI GEOMET® Coated Rotors
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Stopping Never Looked So Good
Fits:
R60 MINI Countryman (2011+)
R61 MINI Paceman (2013+)
Click HERE For ECS Geomet Rotors
R60 R61 MINI S/SX(All4) GEOMET® Coated Rotors
Fits:
R60 MINI Countryman S/SX(ALL4) (2011+)
R61 MINI Paceman S/SX(ALL4) (2013+)
Click HERE For Geomet Rotors
MINI R56+ NM Engineering Wheels
NM Engineering's primary goal is to improve the driver's motoring experience without changing the essence of what makes MINI a MINI.
Now available through ECS Tuning, browse through the stunning catalog of 18" and 17" NM Wheels for your MINI R56+.
Achieve an aggressive race look with the 12-spoke classic mesh design of the RSe12, available in Gunmetal or Black.
The RSe05 is a crisp, clean traditional 5-spoke that fits the more subdued MINIs - Choose from Satin Black, Satin Gunmetal, Red, and Satin Bronze finishes.
Authentic NM
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008-2014)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe'/S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE For NM Engineering Wheels
R50, R52, R53 NM Engineering Wheels
Now available through ECS Tuning, browse through the stunning catalog of 18" and 17" NM Wheels for your MINI R50/R52/R53.
Authentic NM
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Aug 12, 2015 01:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
