::ECS Tuning:: Auto Trans Filter Kit R60 R61 | ECS Timing Chain Kits | NM Eng. Wheels
Old Apr 21, 2015 | 11:00 AM
MINI R60 R61 Automatic Transmission Filter Kit
The MINI Steptronic transmission is highly sensitive to poorly filtered or low fluid levels.
Symptoms of a transmission in need of service are lurching during acceleration and occasional gear slipping.
The ECS Assembled MINI Steptronic Automatic Transmission Service kit are an excellent way to take care of your advanced automatic transmission in one servicing.
The kit includes the transmission filter, pan gasket with gasket dowel pins (washers).
A Critical Component!
R60 MINI Countryman /S/SX(All4)/JCW (2011+)
R60 MINI Paceman /S/SX(All4)/JCW (2013+)
Click HERE for Trans filter kit
R55/R56/R57/R58/R59 MINI JCW Timing Chain Kit
ECS has assembled a timing chain kit with all the parts you need to do a complete timing chain replacement on your MINI. Chains, guides, pins, and tensioners.
Don't wait until that loose, noisy chain jumps time, causing a catastrophic engine failure. If your timing chain is slapping the guides loud enough to make noise, don't just turn up the radio, save your engine.
ECS Tuning. Great parts. Great timing!
Just In Time
Fits N14 Engine:
R56 MINI Cooper JCW (2009-2012)
R55 MINI Clubman JCW (2009-2012)
R57 MINI Cooper Convertible JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE ECS Timing Kits
R50 R52 R53 MINI Timing Chain Kits
Just in Time.
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Click HERE For Gen 1 Timing Kits
MINI F56 NM Engineering Wheels
NM Engineering's primary goal is to improve the driver's motoring experience without changing the essence of what makes MINI a MINI.
Now available through ECS Tuning, browse through the stunning catalog of 18" NM Wheels for your MINI F56.
Achieve an aggressive race look with the 12-spoke classic mesh design of the RSe12, available in Gunmetal or Black.
The RSe52 is a crisp, clean traditional 5-spoke that fits the more subdued MINIs - Choose from Satin Black, Satin Gunmetal, and Satin Bronze finishes.
Authentic NM
Fits:
F56 MINI Cooper / S (2014+)
Click HERE For NM Engineering
R55 R56 R57 MINI Cooper N14 Vacuum Pump
If the brakes in your MINI have begun to feel a little soft, or stopping isn't as precise and powerful as they used to be, the problem may be your vacuum pump.
This is used for the wastegate actuation on the turbo.
The vacuum pump assists the power braking system in providing ample braking pressure.
ECS now offers a Vacuum Pump from Pierburg for your R55/R56/R57 N14-powered Cooper S/JCW.
Pump Up Your Brakes
Fits: N14 Engine
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
Click HERE For Pierburg
R58 R59 MINI Cooper N14 Vacuum Pump
ECS now offers a Vacuum Pump from Pierburg for your R58/R59 N14-powered JCW.
Pump Up Your Brakes
Fits: N14 Engine
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
