Recommended vendor for purchasing OEM Wheels
Old Apr 20, 2015 | 07:57 AM
adamjb's Avatar
adamjb
Hi All,
I have a 2009 mini cooper clubman S and I am looking for some new wheels, and I would like to know a trusted source for OEM rims, any suggestions.
When I search online I see many OEM Wheel vendors are selling reconditioned rims, the price is right, should I be concerned.
Any good experiences and recommendations?
Thanks in advance
Adam
Old Apr 20, 2015 | 08:08 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Selling a set I was going to use....ended up with aftermarket instead.
New in box.
http://nemini.org/index.php?topic=3239.0
Old Apr 20, 2015 | 08:18 AM
We have OEM wheels , all new in box. 9/2009 was the split year on the factory TPMS sensors. So if you get new wheels you will need the pre 9/2009 likely for your 09.
There are R90 MINI wheels on sale as well as some Wheel / Tire sets ( 4 sets ) with those pre 9/2009 sensors.
Also if you have the JCW Brake package ( 4 piston brembo up front ) only certain wheels will fit with those.
Here is all the OEM wheels , all are singles and some styles are in set of four. The R code example R113 is what is used to reference them also, the OEM 11 digit part number.
http://www.ecstuning.com/Mini-2009-Cooper-R55-S_Clubman-Coupe-L4_1.6L_N14B16A/Wheels/OEM_Alloys/
Old Apr 20, 2015 | 08:56 AM
adamjb's Avatar
adamjb
ECSTuning, thanks for the info and links.
I do not have the JCW brake package. The car is a 2009 Clubman S with 205/45/R17 tires.
Can you quote this 4 wheel package: http://www.ecstuning.com/Mini-2009-C...oys/ES2784838/ with TPMS sensors and mini center caps?
The the wheels in this package are brand new, correct?
You can email me at barrettadvert@gmail.com
Adam
Old Apr 20, 2015 | 09:03 AM
Add to cart those wheels , the up to 9/2009 ( which you vin should be pre 9/2009) just double check you production date on the door jam sticker , and the MINI or JCW center caps.
Click here: For all those items added.
www.ecstuning.com/cart
Then input your zip and location and select continue and the shipping option you want. Then checkout.
They are all brand new, all our Genuine MINI parts are.
Old Apr 20, 2015 | 09:22 AM
adamjb's Avatar
adamjb
Thanks ECSTuning
Old Apr 20, 2015 | 11:10 AM
You are welcome.
W0TM8
Dec 19, 2019 07:50 AM
blackie
Oct 2, 2015 07:41 PM
Mini'mon
Aug 16, 2015 04:15 PM
FLYM1N1
Aug 16, 2015 01:15 PM
