Driving lights harness connectors...
Old Apr 19, 2015 | 12:27 PM
ggrimm01's Avatar
ggrimm01
Hey all
I am needing the driving light connectors on the wiring harness. I have looked all over realoem and google and can not find any replacement. This is for 2013 non s driving lights. Thanks
Old Apr 19, 2015 | 01:56 PM
Capt_bj's Avatar
Capt_bj
looking at the install instructions here
http://www.minimania.com/pdfile/R56_Rally_Lights.pdf
are you talking about parts K and/or L (see parts list page 4)
if so .... cut the connector end off and use a generic connector (spade type would work fine) or just solder things up and water seal (I'd use heat shrink tube)
nothing special here, you are just connecting a 12v line and a ground to each light. Do you really need a connector in between? The connector is just another place for water to get in a cause a short! I'd solder and heat shrink . . .
Old Apr 19, 2015 | 08:10 PM
ggrimm01's Avatar
ggrimm01
Driving lights
Those are the ones. I am looking for the harness side connectors. Not the light side. I want to keep everything OEM. Looking for the part numbers.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
nismo4life
Aug 5, 2015 08:31 AM
