:: ECS Tuning :: R60 / R61 Timing Chain Kits | FORGE Header Tank | Vaico Trans Filter
MINI R60/R61 N16 Engine Timing Chain Kit
ECS has assembled a timing chain kit with all the parts you need to do a complete timing chain replacement on your MINI. Chains, guides, pins, and tensioners.
Don't wait until that loose, noisy chain jumps time, causing a catastrophic engine failure. If your timing chain is slapping the guides loud enough to make noise, don't just turn up the radio, save your engine.
ECS Tuning. Great parts. Great timing!
Just In Time.
Fits N16 Engine:
R60 MINI Countryman (2011+)
R61 MINI Paceman (2013+)
Click HERE for ECS Timing kit
MINI R60/R61 N18 Engine Timing Chain Kit
Just In Time
Fits N18 Engine:
R60 MINI Countryman S/SX(ALL4)/JCW (2011+)
R61 MINI Paceman S/SX(ALL4)/JCW (2013+)
Click HERE ECS Timing Kits
MINI R55/R57 Forge Alloy Header Tank
Leave it to Forge Motorsport to accept the challenge and improve on an already brilliant design.
Forge is now offering a stunning Alloy Header Tank replacement for the MINI R55/R57.
The polished alloy tank is a direct-fit replacement for the factory unit, and completely resists the cracking and fading of the original part.
The alloy coolant tank also adds a high-performance, premium look to your engine bay.
Forge Ahead
Fits:
R55 MINI Clubman / S/ JCW (2008-2014)
R57 MINI Cooper Convertible / S/ JCW (2009+)
Click HERE For Forge Header tanks
MINI R56 S/JCW Forge Alloy Header Tank
Forge is now offering a stunning Alloy Header Tank replacement for the MINI R56 S/JCW.
Forge Ahead
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
Click HERE For FORGE Header Tank
MINI R55 R56 R57 Automatic Transmission Filter Kit
The MINI Steptronic transmission is highly sensitive to poorly filtered or low fluid levels.
Symptoms of a transmission in need of service are lurching during acceleration and occasional gear slipping.
The ECS Assembled MINI Steptronic Automatic Transmission Service kit is an excellent way to take care of your advanced automatic transmission in one servicing.
The kit includes the transmission filter, and pan gasket with gasket dowel pins (washers).
A Critical Component!
Fits:
R56 MINI Cooper / S (2007-2013)
R55 MINI Clubman / S (2008-2014)
R57 MINI Cooper Convertible / S (2009+)
Click HERE For auto trans filter kits
MINI R58 R59 Automatic Transmission Filter Kit
The ECS Assembled MINI Steptronic Automatic Transmission Service kit are an excellent way to take care of your advanced automatic transmission in one servicing.
The kit includes the transmission filter, pan gasket with gasket dowel pins (washers).
Fits:
R58 MINI Coupe' / S (2012+)
R59 MINI Roadster / S (2012+)
Click HERE For Auto trans kits
Aug 11, 2015 11:58 AM
Aug 10, 2015 01:59 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
