Tire brand for 16x8 +20 wheels...
Old Apr 14, 2015 | 11:40 PM
David Chen's Avatar
David Chen
Just got my wheels back from powder coating and pretty sure i'm going with 205/45/16. Does anyone know a good brand of tire that they can recommend that doesn't have too square of sidewalls?
Thanks,
David
Old Apr 15, 2015 | 09:37 AM
hsautocrosser's Avatar
hsautocrosser
Tirerack.com has pictures of the tires they sell. Search by size, then filter results by other parameters such as runflat, all-season, load, speed rating, etc. And, of course, you'll be stretching a 205/45 on an 8" wheel.
Old Apr 16, 2015 | 06:57 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
A search of tirerack.com in that size yields-
http://www.tirerack.com/tires/TireSe...erformance=ALL
What are you going to use your MINI for? Street use only vs track, autocross, car shows?
What are your priorities? Comfort, handling and performance Dry vs Wet, long treadlife, strict budget, noise, appearance?
What is your weather like where you will be driving? Any cold weather less than 40 degrees?
Note that tire size fits rims 6.5-7.5" wide and is perfect for a 7" wide rim so as mentioned your fitment on the 16x8" will be a tire stretch. This automatically rounds out the shoulder treads due to the stretch and puts more stress on the sidewalls that have to function to support weight and resist flex under load and serve as treads to contact the road. For performance driving this would be the last thing you would want to do if given a choice. For car shows, it's done all the time. Note too that with so little tire your wide wheels will be prone or be at risk for curb rash. In addition a compromised sidewall is not going to be suited for bad roads so be careful or you can damage your rim, suspension or tire going over a pothole.
Old Apr 22, 2015 | 01:11 AM
David Chen's Avatar
David Chen
Thanks for the time you spent answering this. Sorry I didn't get a chance to check back earlier but I ended up going with 205-50-16 Toyo Proxes 4 plus. It really doesn't seem to be a stretch and the tire protects the wheel from curb rash.
I'll take a picture once everything is on the car.
thanks again!
David
CM2011RG
Apr 12, 2016 12:44 PM
MINI VINI
Oct 13, 2015 08:57 AM
seanle
Oct 7, 2015 07:43 AM
blackie
Aug 25, 2015 09:08 PM
Mini'mon
Aug 16, 2015 12:47 PM
