:: ECS Tuning :: ECS Geomet Cross Drilled / Slotted Rotors : Gen 2 Timing Chain Kits
R58/R59 MINI Coupé/Roadster SPC Front Camber Plates
For the R58/R59 MINI, suspension adjustability yields huge gains in handling characteristics.
SPC Performance Front Adjustable Camber Plates are an excellent investment for the MINI owner looking to dial in a more aggressive front camber and caster specification, keeping the tire contact patch more parallel with the road surface during hard cornering when traction is most needed.
The aluminum plates are coupled with an OE-style bearing within a bonded urethane insulator, allowing for +/- 2 degrees of camber and +/- .75 degrees of caster adjustment.
Dialed-In Performance
Fits:
R58 MINI Coupé /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for SPC
R56 MINI Cooper GEOMET® Drilled & Slotted Brake Rotors
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
Slotted or drilled and slotted, you can expect your new GEOMET® rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Stopping Never Looked So Good
Fits:
R56 MINI Cooper (2007-2013)
*Not for JCW Brembo Sport Brakes
Click HERE ECS Geomets
R57 MINI Cooper GEOMET® Drilled & Slotted Brake Rotors
Slotted or drilled and slotted, GEOMET® rotors outperform and outlast factory R57 MINI Cooper rotors, and look stunning behind alloy wheels.
Fits:
R57 MINI Cooper Convertible ( NON S ) (2009+)
***Not for JCW Brembo Sport Brakes**
Click HERE For ECS Geomets
R55 MINI Cooper GEOMET® Drilled & Slotted Brake Rotors
Slotted or drilled and slotted, GEOMET® rotors outperform and outlast factory R55 MINI Cooper rotors, and look stunning behind alloy wheels.
Fits:
R55 MINI Clubman (2008-2014)
MINI R55 R56 R57 N12 ECS Timing Chain Kit ( Cooper NON S )
ECS has assembled a timing chain kit with all the parts you need to do a complete timing chain replacement on your MINI. Chains, guides, pins, and tensioners.
Don't wait until that loose, noisy chain jumps time, causing a catastrophic engine failure. If your timing chain is slapping the guides loud enough to make noise, don't just turn up the radio, save your engine.
ECS Tuning. Great parts. Great timing!
Just In Time
Fits N12 Engine:
R56 MINI Cooper (2007-2010)
R55 MINI Clubman (2008-2010)
R57 MINI Cooper Convertible (2009-2010)
Click HERE For timing chain kits
MINI R55 R56 R57 ECS Timing Chain Kit ( Cooper S ) N14
Just In Time
Fits N14 Engine:
R56 MINI Cooper S (2007-2010)
R55 MINI Clubman S (2008-2010)
R57 MINI Cooper Convertible S (2009-2010)
Click HERE For Timing Chain kits
MINI R55 R56 R57 R58 N16 Engine Timing Chain Kits ( Cooper NON S )
Accurate and reliable engine timing requires the cooperation of several critical components. Wear is typically systemic - meaning as one component wears significantly, other parts begin to lose functionality and fail, beginning a cumulative effect of system failure.
To avoid the catastrophic consequences inherent in timing system failure, invest in an ECS assembled Timing Chain Kit.
The ECS kit includes carefully selected components for a thorough refresh - a new timing chain and chain tensioner, timing chain guide rails, inlet cam bolt, outlet cam bolt, and crankshaft gear.
Right on Time
its: N16 Engine
R56 MINI Cooper (2011-2013)
R55 MINI Clubman (2011-2014)
R57 MINI Cooper Convertible (2011+)
R58 MINI Coupe' (2012+)
R59 MINI Roadster (2012+)
MINI R55 R56 R57 R58 N18 Engine Timing Chain Kits ( Coopes S )
To avoid the catastrophic consequences inherent in timing system failure, invest in an ECS-assembled Timing Chain Kit.
Right on Time
Fits: N18 Engine
R56 MINI Cooper S (2011-2013)
R55 MINI Clubman S (2011-2014)
R57 MINI Cooper Convertible S (2011+)
R58 MINI Coupe' S (2012+)
R59 MINI Roadster S (2012+)
Click HERE For Timing Chain Kit
Accessory Products
Aug 11, 2015 12:59 PM
Aug 11, 2015 12:58 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 12:34 PM
Accessory Products
Aug 11, 2015 12:19 PM
