Suspension Interim Coilover Thoughts
Old Apr 7, 2015 | 10:44 PM
Aelwulf's Avatar
Aelwulf
I'm pretty sure the rear driver side strut is starting to go out since I'm starting to rub when I hit a big bump. Unfortunately I can't swing the full upgrade I'd like, but since I also can't be 100% that the others aren't about to start going out as well I'd like to upgrade at least some extent. So here's what I'm looking at, thoughts? I get the swift &/or custom valving will work better than others, just looking for opinions if it'd be worth it. I mostly do daily driving with some sport driving in hills/on interstate.
http://circuitmotorsports.net/megan-.../i-519582.aspx
http://www.tunersports.com/bc-racing...02_p19405.html
http://www.circuitmotorsports.net/bc.../i-532686.aspx
http://www.greeneperformance.com/pro...custom-revalve
Old Apr 8, 2015 | 08:00 AM
Grizld700's Avatar
Grizld700
Any of these will work fine. If I remember correctly, you were planning on Ohlins next year maybe? I'd just do the Megans if you're thinking you'll use them for only a year. Least expensive, do an ok job, plenty of adjustment. Plus they sell fairly fast on the marketplace.
Old Apr 8, 2015 | 06:33 PM
Aelwulf's Avatar
Aelwulf
I was, but that was when I was going to get the iPE this year. After my wife's 180 and wanting to get $5,000 in appliances this year instead of next year it all got pushed. And after some discussions we'll see in the end since I won't track like many here do. At least not for several years since the kids are too young. :p
Old Apr 9, 2015 | 08:57 AM
mbwicz's Avatar
mbwicz
There are a set of H&R street coil overs on the marketplace for $800, also a set of FSD's for $400 if you want to keep it simple. There are also normally guys selling used OEM stuff there.
If it was me, I would keep saving for the high end coil overs and put the minimum into the car for a year. You may be frustrated with $1000 coil overs.........
Have fun,
Mike
Old Apr 9, 2015 | 09:14 AM
Helix13mini's Avatar
Helix13mini
My recommendation would be to replace the broken parts you have now and save for the coilover setup that you really want. Here's the thing about cheap coilovers: they don't last--particularly the shocks. You'll just end up in the same boat you are in now in 6 months if you try to compromise on the dampeners.
Ryan Caballo
Sep 10, 2015 10:10 AM
freckles81
Sep 8, 2015 09:48 AM
RIchard Nguyen
Sep 6, 2015 07:21 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
