Free Shipping This Week Only at Mini Mania!
FRONT MOUNT INTERCOOLER UPGRADE STREET - R55/56/57 COOPER S 2007-2010
Intercooler Upgrade for increased capacity and efficiency - this is the 'Standard version' for 2007-2010 models. An oversized Air-to-Air Intercoler Upgrade reduces inlet temperatures and improves performance. As the inlet temperature is reduced, the air becomes 'more dense' packing a greater number of O2 molecules, which results in a more powerful combustion. This nets more horsepower to the wheels! Have you noticed how your Turbo engine seems more powerful and responsive when the weather is col
*To the contiguous USA only.
BLOW OFF VALVE UPGRADE KIT - R55/56/57/58/59/60 COOPER S 2011+
Blow Off Valve Kit recommeded for the MINI Cooper S with increased boost, or simply for those wanting a loud Blow off sound or simply as a solution to the many failures that have occurred. For the Cooper S with the N18 Turbocharged engines, these are Cooper S 2011 onwards and JCW Cooper S 2013 onwards.. Fits the following Cooper S models: 2011+ R56 Cooper S Hatchback 2011+ R55 Cooper S CLUBMAN 2011+ R57 Cooper S Convertible 2011+ R60 Cooper S COUNTRYMAN 2012+ R58 Cooper S COUPE
Mini Cooper S Intake Hi-Flow w/o Tube 04/2012+ R55 R56 R57 R58 R59 R60 R61
A lower cost Hi-Flow intake system without the Inlet Tube for the turbocharged MINI Cooper S models with the N18 engine. Stainless brackets and silicone couplings are all designed, engineered and manufactured to fit and perform. Fits the following Cooper S models with production date 04/2012 and later: 04/2012-2013 R56 MINI Cooper S Hardtop 04/2012-2014 R55 MINI Cooper S Clubman 04/2012-2015 R57 MINI Cooper S Convertibles 04/2012-2015 R58 MINI Cooper S Coupe 04/2012-2015 R59 MINI Cooper S
MINI Cooper Ignition Coil Packs, by Ignition Ignition Projects
The IP Coils are the ignition coil with a high power amplifier built in to it. The IP Coils produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engine
INTERIOR CHROME KIT 27 PIECES - R55/56/57 MINI COOPER & S
Interior Chrome Kit to dress up your MINI! Chromed plastic overlay simply attaches over existing trim for simple installation. Fits the following models: 2007-2013 R56 MINI Cooper and Cooper S Hardtop2008-2014 R55 MINI Cooper and Cooper S Clubman2009-2015 R57 MINI Cooper and Cooper S Convertible NOTE: This kit fits the above models with the single tachometer on the steering column. If you have the tach and speedo on the steering column, this kit does not include the chrome trim that
chrisx18240
26
Mar 16, 2022 09:56 AM
jrezzo
Aug 9, 2015 10:32 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
