:: ECS Tuning :: Jack Pad Kits ...New Wavetrac Differentials ...... EURO Blind Spots
Old Apr 6, 2015 | 01:19 PM
MIIN Gen2 R55/R56/R57 Jack Pads
Whenever raising your vehicle, safety is the primary concern. Reliability is a close second, and the genuine MINI Cooper Jack Pad Replacements ensure both with their exact-fit design and rugged construction.
The MINI Jack Pad Kit contains 4 pads that provide an excellent surface to place your jack on, making working under your vehicle safer and protecting fragile sheet metal from crushing or deforming.
Another smart investment, take the danger and aggravation out of lifting your MIIN Gen2 R55/R56/R57 with the anodized aluminum ECS Tuning Jack Pad Adapter.
Lift Easy!
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for Jack pads
R52/R53 MINI WAVETRAC® Front Limited Slip Differentials
Most truly performance-engineered European sports cars utilize a limited-slip style differential.
While an open differential effectively accomplishes the task of allowing one wheel to spin faster than the other around corners, during power delivery, this behavior is not always desirable.
In order for the full measure of power to be distributed to both wheels of your R52/R53 MINI, the Wavetrac® Torque-Biasing Differential automatically improves grip in low traction conditions while putting all your power to the ground.
On Trac for Performance
R52 MINI Cooper Convertible S / JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE WaveTrac
R50/R52/R53 MINI Euro Blind Spot Mirrors
Horn blasts and sideswipe near misses during lane changes are scary stuff. If you're lucky, all you get is a massive dose of horn before swerving back to your own lane. Where did HE come from?
Genuine European MINI R50/R52/R53 Heated Blind Spot mirrors expand your rear vision area to include that guy shadowing your quarter panel.
Easy to install, these mirrors look good, and make merging with traffic a non-contact sport.
Now You See Me
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper /S/JCW ( 2005-2008 )
R53 MINI Cooper S/JCW ( 2002-2006 )
Click HERE For Gen 1 Blind Spot mirrors
MINI R58/R59 S/JCW ECS Jack Pad Adapters
Take the danger and aggravation out of lifting your MINI with the ECS Tuning Jack Pad Adapter. Designed to fit the head of a standard floor jack, the adapter has a rectangular head that firmly engages the chassis jack pads.
Positive engagement at jack head and chassis resists jack slippage and shifting, while the raised adapter head prevents damage to rocker panel trim and underbody panels.
Made of black anodized aluminum for added strength and corrosion resistance, the adapter fits the head of most hydraulic floor jacks, including the excellent Schwaben Low Boy.
Raise your Standards
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE For ECS Jack Pad Adapters
MINI R50/R53 Genuine MINI Valve Cover
Is your MINI Valve Cover cracked and leaking? Are the bolts unsightly and corroded?
If it's time to clean up your engine, you can put your troubles behind you. The Genuine MINI Valve Cover is now available!
A quick and easy installation, this new valve cover comes complete with the MINI logo, a new oil cap, all new hardware, gasket, and spark plug tube seals.
Just when you thought it couldn't get any better, it comes completely assembled with the gaskets in place and the hardware installed. The perfect part, and all for a price that makes it difficult to resist!
Quick & Easy
Fits:
R53 MINI Cooper S/JCW (2002-2006)
Click HERE For Valve cover kits
MINI R52 Genuine MINI Valve Cover
Quick & Easy
Fits:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
R55 MINI Cooper SPC Front Camber Plates
For the R55 MINI, suspension adjustability yields huge gains in handling characteristics.
SPC Performance Front Adjustable Camber Plates are an excellent investment for the MINI owner looking to dial in a more aggressive front camber and caster specification, keeping the tire contact patch more parallel with the road surface during hard cornering when traction is most needed.
The aluminum plates are coupled with an OE-style bearing within a bonded urethane insulator, allowing for +/- 2 degrees of camber and +/- .75 degrees of caster adjustment.
Dialed-In Performance
Fits:
Click HERE For SPC
R57 MINI Cooper SPC Front Camber Plates
For the R57 MINI, suspension adjustability yields huge gains in handling characteristics.
Fits:
Click HERE For SPC
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
