R56 failed the smog check due to P0015 and P0030
I got failed from the smog check.
because of P0015 and P0030
What do the codes stand for?
What kind of repair should I do to my mini cooper 2007
And could you please estimate the price of repairing it and is it possible I can fix by my self.
I have to renew my registration by April and I don't have much time. lol...
Thank you.
Thank you.
if you just type into google search Mini code and # u get this.
What does this mean?
OBD Code P0030refers to
Oxygen Sensors (O2S) or Heated Oxygen Sensors (HO2S) need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. The faster the heated oxygen sensor reaches that temperature the faster the sensor will start sending an accurate signal to the Engine Control Module (ECM). In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The ECM controls the heater element circuit by allowing current flow to ground. The ECM monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
Symptoms
Possible sumptoms of OBD code P0030
- Engine Light ON (or Service Engine Soon Warning Light) - Engine may be running rich - Fuel vapour from Exhaust - Low MPG
Causes
Possible causes of OBD code P0030
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection - Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse - Faulty Engine Control Module (ECM) The Error code is generally activated on detection of the following conditions: The P0030 is set when the ECM detects an open or shorted to ground condition on the heated oxygen sensor heater circuit
Possible Solutions
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. HO2S Heater Control Circuit Bank 1 Sensor 1 is the generic definition for the P0030; however your vehicle's manufacturer may have a different definition and information for the P0030 code.
Symptoms
Causes
Possible Solutions
alex87f
Mar 25, 2017 03:46 PM
L3Mix
Aug 26, 2015 07:00 PM
