FS:: Mini Madness - Madness Motorworks - R53 header
Old Mar 31, 2015 | 11:25 AM
CornerHugger's Avatar
CornerHugger
Price: $525
Location (Region): NorthWest
Madness Motorworks - R53 exhaust header
This header rocks! I sadly had to remove it because I have other headers and I needed the money more than the torque. The Mini misses it
The flex joint was leaking so I just bought a new flex joint and had it welded on by Mini Madness themselves. Works perfectly.
I'm including the original test pipe that has a special BMW extension joint added (pre-installed and fitted to work with most exhausts). This makes the pipe the perfect length to connect to typical cat-backs and the install for this header is now bolt-on and drive. Also you can shrink or expand the pipe for perfect fit a custom exhaust setup. Also, you can remove the test pipe and install a custom catted pipe very easily.
The test pipe also has an extra welded o2 bung installed as well for an AFR sensor and I'll include an o2 plug in case you don't have an AFR.
Price is shipped to your door (in USA).
Note: The aftermarket CAT seen in the pics will not be included.
Attached Thumbnails Mini Madness - Madness Motorworks - R53 header-img_20141026_161713.jpg
Old Apr 1, 2015 | 12:22 PM
hellothom's Avatar
hellothom
This text post cannot explain the amount of want I have for this part...
GLWS, fellow Portlander!
Old Apr 1, 2015 | 11:19 PM
PhoR53's Avatar
PhoR53
Nice looking header!!! will you lower your asking price by any chance. just asking. Thanks
Old May 8, 2015 | 09:33 AM
CornerHugger
All moved in to new place. Ready to ship!
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
