FS:: 2nd Gen Bi-xenon modded headlamps
Old Mar 30, 2015 | 04:05 PM
rckrzy1's Avatar
rckrzy1
SOLD 2nd Gen Bi-xenon modded headlamps
Category: Lights
Price: $500
Part fits (you may select multiples): R55, R56, R57
Location (Region): Texas
LIGHTS ARE SOLD
Ok, just finished modding a set of 2013 (fits 07-14) headlights and my wife goes and trades in her hardtop for a convertible that comes with xenon.
Took factory 2013 in mint condition, installed H1 Bixenon projectors , painted black, using OPT7 quality AC 35W ballast's , relay control cable , 50W 8 OHM resistors mounted to heat sinks (4 total ) so NO error or bulb out warnings.
It took me countless hours to come up with a truly plug n play , no programing, no error setup and too many man hours of cutting , grinding, sanding to fit projectors in a truly nice looking , great functioning set up as I'm quite **** when it comes to cars, then the wife changes everything by getting a new car.
These have been used 2 weeks , I extended the relay cable so you can mount cable along front of radiator with ease, the ground wires go under the nut on the strut tower, all you have to do is drill a small hole into your battery area and attach to pos term.
$500 plus shipping , I have large boxes ready to go just need to calculate shipping for your area,
Old Apr 2, 2015 | 09:20 AM
solskjaer1999's Avatar
solskjaer1999
Are these from Black Flames Customs? Are the plug and play for factory halogen headlights?
Old Apr 2, 2015 | 10:29 AM
rckrzy1's Avatar
rckrzy1
these are from me customs. I took mint condition 2013 halogen assy's and moddified them with H1 mini projectors, painted black, tested and reassembled
and one day later wife bout a new R57 with xenons. I tested these for function, hi lo all work perfect, uses OPT7 AC 35W ballast, relay harness attaches to the pass side H13 factory connector, the drivers side just gets a resistor pack , there is NO ERROR, NO BULB out codes, NO programming, if your car has halogen with A h13 bulb these are PLUG N PLAY. You need to attach the positive lead to the battery, attach both grounds, found the strut bolt a good place , tuck the resistor/heatsink in , there is plenty of room, attach h13 on pass side to relay control in , route cable across radiator, I made the cable to perfect fit any R55 R56 R57 .
AGAIN You won't find an easier set up, the back door of the head assy has cables fed through the middle, grommet installed, all you have to to align after install.
I have found shipping to be about $60-80 insured.
If my wife did not trade in her R56 I would be using these today.
Old Apr 3, 2015 | 09:57 PM
corin.mcblide's Avatar
corin.mcblide
any pictures of output? i've been to do this but dont trust my electrical skills
Old Apr 3, 2015 | 10:01 PM
rckrzy1's Avatar
rckrzy1
Sorry have a deposit for these allready . With 35w H1 they are great.
Old Apr 17, 2015 | 07:40 PM
rckrzy1's Avatar
rckrzy1
sold, shipped and delivered .
Emnotek
Sep 11, 2015 04:16 PM
Eurothrasher
Sep 9, 2015 12:00 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
