:: ECS Tuning :: Gen 1 & 2 ECS Strut Tower Plates : Ziza R50 / R53 Interior LEDs !
Old Mar 23, 2015 | 01:37 PM
MINI R58/R59 ECS Strut Tower Plates
The strut tower for the MINI R58/R59 Cooper was designed to adequately support the stresses and forces encountered during typical daily driving.
Aging models or vehicles that are routinely pushed past the limitations of the chassis oftentimes experience strut tower deformation, compromising the crisp and responsive handling that defines every MINI.
Machined from 15mm thick 6061-T6 aluminum, ECS Strut Tower Plate Kits eliminate the prospect of tower mushrooming while improving chassis rigidity for your MINI R58/R59 Cooper.
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for ECS Strut Tower Plates Gen 2
R50 R53 Ziza LED Performance Lighting Kits
You won't believe the difference an LED lighting package makes for your MINI R50 R53 until you see it with your own eyes.
LED illumination is a far brighter and friendlier light - crisp and clean, especially when compared to the dingy yellow glow from conventional filament style bulbs.
Now you can do a complete LED conversion using our Ziza LED Interior Lighting Kit.
Included are all LEDs needed for complete lighting upgrade - No need for guesswork or complicated ordering of individual bulbs.
Light 'em Up
Fits:
R50 MINI Cooper (7/2004-2006)
R53 MINI Cooper S / JCW (7/2004-2006)
Click HERE for Ziza interior LED kits
R50/R52/R53 MINI Cooper
If you need technical information about your MINI for repair or simply for personal satisfaction, a Bentley service manual is a must-have item.
DIYers will appreciate the detailed repair procedures and reference data that have made Bentley a trusted source of information for decades and the industry benchmark for aftermarket technical books on European makes.
Owners hungry for a better understanding of the technology and features that make MINI special will enjoy the richly illustrated, detailed explanations of vehicle components, assemblies, and operating strategies.
Bentley Wrote the Book!
Fits :
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible /S/JCW (2005-2008)
Click HERE For Bentley Manuals
R60 MINI Countryman S/SX/JCW Pressure Converter
Feeling a little sluggish?
The performance of your MINI thrives on the ability of the turbocharger. Even the smallest of pressure leaks can slow you down and turn your check engine light on.
Don't let any of that power get away with a worn pressure transducer. A common problem with turbo control systems, this Pressure Converter from Pierburg will bring your boost levels back to where they should be, and help get rid of that annoying check engine light!
Now more affordable than ever from the OEM manufacturer, fix vacuum leaks and boost problems with one simple repair.
Under Pressure?
Fits:
MINI R60 Countryman S/SX/JCW (2011+)
Click HERE here for Pierburg
R50/R53 ECS Strut Tower Plates
The strut tower for the MINI Cooper was designed to adequately support the stresses and forces encountered during typical daily driving.
Machined from 15mm thick 6061-T6 aluminum, ECS Strut Tower Plate Kits eliminate the prospect of tower mushrooming while improving chassis rigidity for your MINI Cooper R50/R53.
ECS - Smart and Simple
Fits:
Click HERE for the ECS Strut Tower Plates
R52 Convertible ECS Strut Tower Plates
Fits:
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
