:: ECS Tuning :: KONI SALE Gen 1 & Gen 2 [] F56 Splash Guards [] DEPO Gen 1 Black HL
R55-R59 MINI Cooper/S/JCW Koni Shocks & Struts
Many MINIs have logged significant miles to date, and most have road-weary suspension setups.
KONI Struts and Shocks have been a favorite replacement choice for performance enthusiasts; they offer a perfect blend of even, more stable handling dynamics with ride compliance & comfort.
KONI fine tunes their shocks & strut kits by application, refusing to take the 'one-size-fits-all' approach used by less thorough manufacturers.
Available with Frequency Selective Damping (FSD) technology, KONI shocks and struts are a wise performance upgrade for your R55-R59 MINI Cooper/S/JCW.
KONIs: Move Up, Not Over.
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for KONI FSD
R50, R52, R53 MINI Cooper/Base/S Koni Shocks & Struts
Available with Frequency Selective Damping (FSD) technology, KONI shocks & struts are a wise performance upgrade for your R50, R52, R53 MINI Cooper/Base/S.
Fits:
R50 MINI Cooper (3/2002-2006)
R52 MINI Cooper Convertible / S (2005-2008)
R53 MINI Cooper S (3/2002-2006)
Click HERE for KONI kits
F56 MINI Cooper/S Front & Rear Splash Guard Kit
If you occasionally drive your F56 MINI Cooper/S in snowy, muddy, or rocky areas, there exists the risk that rocks and other road debris will chip your paint or effect other drivers around you.
The genuine OEM MINI Front & Rear Splash Guards keep road debris at bay while adding a unique styling element to your car.
Designed to fit the contour of your F56 MINI's front and rear wheel wells, the direct-fit guards fit snugly at the inner well and attach easily with screws.
These genuine pieces are made of a rubberized material to match the rest of your MINI's styling.
On Guard!
Fits:
F56 MINI Cooper (2014+)
F56 MINI Cooper S (2014+)
Click HERE For the kits
MINI R50 R53 Depo Blackout Headlights
Depo now offers Blackout Headlight Housings with Chrome rings for your MINI R50 R53.
The DOT/SAE compliant housings are finished in classic black matte with sophisticated chrome ring surrounds.
These direct-fit headlights are designed to easily replace your factory units in less than an hour.
The headlight design mimics the early Gen 1 MINI Halogen headlights, ensuring that this styling upgrade looks consistent with the rest of the car.
Two H7 Bulbs are required per light housing.
A Tasteful Upgrade
Fits:
R50 MINI Cooper (2002-7/2004)
R53 MINI Cooper S / JCW (2002-7/2004)
*without headlight washers
Click HERE here for Depo kits
MINI R50/R53/R52 Exact-Fit Brake Lines
ECS Exact-Fit stainless reinforced brake lines provide more confident and dependable stopping by maintaining consistent brake pressure, long lasting corrosion resistance, and increased protection from failure.
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Stopping Never Looked So Good
Fits:
R50 MINI Cooper (4/2003+)
R53 MINI Cooper S / JCW (4/2003+)
R52 MINI Cooper / S / JCW (2005+)
Click HERE for the Brake Lines
MINI Gen 1 7/2006+ ECS 25mm & 30mm Wheel Spacers Kits
Don't let conventional spacer options leave you feeling down and out. ECS bolt-on wheel spacers are the right way to push your wheels out to the fenders.
These precision machined, 6061-T6 anodized black aluminum spacers have 4140 integral steel threads. Forget the perils of extra-long wheel bolts; these come complete with all the low profile bolts needed to properly torque the spacers to the hub in factory looking black and your wheels to the spacers.
ECS bolt-on spacers will have your car sitting just wide.
Space Out
Fits:
R50 MINI Cooper (7/2006+)
R52 MINI Cooper Convertible /S/JCW (7/2006-2008)
R53 MINI Cooper S / JCW (7/2006+)
Click HERE for ECS Spacers
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
