:: ECS Tuning :: R56-R59 MINI Cooper S/JCW Pressure Converter
Old Mar 11, 2015 | 01:54 PM
Feeling a little sluggish?
The performance of your MINI thrives on the ability of the turbocharger. Even the smallest of pressure leaks can slow you down and turn your check engine light on.
Don't let any of that power get away with a worn pressure transducer. A common problem with turbo control systems, this Pressure Converter from Pierburg will bring your boost levels back to where they should be, and help get rid of that annoying check engine light!
Now more affordable than ever from the OEM manufacturer, fix vacuum leaks and boost problems with one simple repair.
Under Pressure?
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for the Pressure Converter
Aug 7, 2015 09:51 AM
M7Speed
Aug 6, 2015 01:48 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
