:: ECS Tuning :: Gen 1 DEPO Fog Lights] Gen 2 07-10' DEPO LED Taillights] JCW GP2 ECS
R50/R53 MINI Depo Fog Lights
An area of the front of the R50/R53 MINI that often receives road wear and damage is the fog lights.
When the units become cracked, hazy, or excessively scuffed, the driver can lose visibility and the front of the car can look overly worn.
Depo replacement Fog Lights mount on the lower front bumper, and are a direct replacement for your factory housings.
Both left and right fog lights are included, and also come with a bulb and socket.
Direct-fit Replacements
Fits:
R50 MINI Cooper (6/2002-2006)
R53 MINI Cooper S/ JCW (6/2002-2006)
Click HERE for Depo gen 1 fog lighst
MINI R57 Depo LED Tail Light Sets
Add eye-catching LED lighting from DEPO to your MINI with clear or smoked tail lights with LED brake lights.
These show-stopping tail light upgrades are complete LED units that plug and play with your stock wiring harnesses without causing any "bulb out" warnings.
Utilizing a smart, simple design, these tail lights look like they could have come on your MINI from the factory, and are ECE and SAE compliant.
Using bright LED lights in place of the standard brake light bulbs, the lights thoroughly update the look of your MINI R57.
PLUG AND PLAY!!
Fits:
R57 MINI Cooper Convertible /S/JCW (2009-2010)
Click HERE for Depo kits
R56 Depo LED Tail Light Sets
Using bright LED lights in place of the standard brake light bulbs, the lights thoroughly update the look of your MINI R56.
PLUG AND PLAY!!
Fits:
R56 MINI Cooper/S/JCW (2007-2010)
Click HERE For the Depo LED Taillights
R52 R53 MINI S/JCW Coolant System Refresh Kits
Replacing cooling system components and performing a proper coolant flush will ensure a long life for your cooling system.
Most of the cooling system components are exposed to very high temperatures and repeated thermal cycling. Heat-hardening causes warping and cracking that leads to coolant loss and possible engine damage from overheating.
Avoid headaches altogether and replace all problematic items at once to keep your cooling system running efficiently.
Keep Your Cool
Fits:
R52 MINI Cooper Convertible S/JCW (2005-2008)
R53 MINI Cooper S/JCW (2002-2006)
Click HERE here for Coolant Service kits
R56-R59 MINI Cooper S/JCW Pressure Converter
Feeling a little sluggish?
The performance of your MINI thrives on the ability of the turbocharger. Even the smallest of pressure leaks can slow you down and turn your check engine light on.
Don't let any of that power get away with a worn pressure transducer. A common problem with turbo control systems, this Pressure Converter from Pierburg will bring your boost levels back to where they should be, and help get rid of that annoying check engine light!
Now more affordable than ever from the OEM manufacturer, fix vacuum leaks and boost problems with one simple repair.
Under Pressure?
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for the Pressure Converter
R52 Cooper Convertible MINI Depo Fog Lights
An area of the front of the R52 Cooper Convertible MINI that often receives road wear and damage is the fog lights.
Fits:
R52 MINI Cooper Convertible/S/JCW (2005-2008)
Click HERE for R52 Fogs
R50/R53 MINI Cooper -6/2002 Depo Fog Lights
An area of the front of the R50/R53 MINI Cooper that often receives road wear and damage is the fog lights.
Fits:
R50 MINI Cooper (-6/2002)
R53 MINI Cooper S/ JCW (-6/2002)
*For MINI owners with pre 6/2002 models replacing the original fog light housing, you will need a harness conversion plug ES9096.
Click HERE for R50 R53 -6/2002 Fogs
R56 MINI JCW GP 2 ECS Tuning Exact-Fit Brake Lines
If you spend time and money renewing your brake hardware and linings, use this time to upgrade to the stellar ECS Tuning Exact-Fit brake hoses, and do the job right.
The premium brake hoses are significantly stronger, more reliable, and better protected than those supplied from the factory.
Shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection, the lines look as good as they perform.
Available by the axle for front or rear, or as a complete vehicle set.
Premium Grade. MINI Worthy
Fits:
R56 MINI Cooper JCW GP2 (2013)
Click HERE for JCW GP2
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
