:: ECS Tuning :: NEW ECS Jack Pad Kits } F56 NEW Oil Service Kits } Gen2 Thermostats
Old Mar 4, 2015 | 01:20 PM
MINI R50/R52/R53 Cooper Jack Pad Replacements
Whenever raising your vehicle, safety is the primary concern. Reliability is a close second, and the genuine R50/R52/R53 MINI Cooper Jack Pad Replacements ensure both with their exact-fit design and rugged construction.
The MINI Jack Pad Kit contains 4 pads that provide an excellent surface to place your jack on, making working under your vehicle safer and protecting fragile sheet metal from crushing or deforming.
Another smart investment, take the danger and aggravation out of lifting your MINI with the anodized aluminum ECS Tuning Jack Pad Adapter.
Lift Easy!
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible /S/JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE for jack pad kits
R56 R55 R57 MINI N12 Thermostat Replacement Kit
Prevent cooling issues before they begin with an ECS Tuning Thermostat Replacement Kit.
The experts at ECS have identified all of the common parts that tend to wear significantly or fail and have assembled a comprehensive kit including all replacement parts for a thorough refresh.
If your MINI has high miles or has an unreliable thermostat, replace all the critical components at the same time for added assurance.
Hot or Cold?
Fits:
R55 MINI Clubman (6/2010-3/2012)*
R56 MINI Cooper (6/2010-3/2012)*
R57 MINI Cooper Convertible (6/2010-3/2012)*
*additional Adapter Lead needed
Click HERE for Thermostat kits
F56 MINI Cooper (NON S ) Oil Service Kits ; 1.5 L
The best oil for your MINI? Clean oil.
Regular oil changes with a quality filter cartridge are cheap insurance against costly breakdowns, and the best way to keep your MINI healthy.
Now you can perform this essential service yourself and save big with MINI Oil Service Kits that contain an OEM filter cartridge with drain plug, plus your choice of name brand engine oils that meet BMW LL-98 and BMW LL-01 standards.
Spend a little up front and head off major repairs, down the road.
MINI essentials
Fits:
F56 MINI Cooper Base (2014+)
Click HERE For the Oil service kits
F56 MINI Cooper S Oil Service Kits ; 2.0L
Regular oil changes with a quality filter cartridge are cheap insurance against costly breakdowns, and the best way to keep your F56 MINI Cooper S healthy.
MINI essentials
Fits:
F56 MINI Cooper S (2014+)
Click HERE here for Oil Service kits
MINI R55/R56/R57/R58/R59 Thermostat Replacement Kit
Hot or Cold?
Fits:
R55 MINI Clubman JCW (6/2010-3/2012)
R56 MINI Cooper JCW (6/2010-3/2012)
R57 MINI Cooper Convertible JCW (6/2010-3/2012)
R58 MINI Coupe' JCW (-3/2012)
R59 MINI Roadster JCW (-3/2012)
MINI R52/R53 S MFactory Limited Slip Differential
Almost every truly distinguished European sports car utilizes a limited-slip style differential.
While an open differential effectively accomplishes the task of allowing one wheel to spin faster than the other around corners, during power delivery, this behavior is not always desirable.
The full measure of power is distributed to both wheels with a Helical LSD, for true performance-car acceleration and handling.
Additionally, upgrading your differential is an excellent time to replace your differential bearings as well. ECS offers SKF Differential Bearings for your MINI R52/R53.
Fit:
R52 MINI Cooper S Convertible / JCW (2005-2008)
Click HERE for M factory
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
