Suspension Looking for a lightweight rim suggestion
Old Feb 24, 2015 | 03:54 PM
'10JCW's Avatar
'10JCW
SO I am buying some new rims while ditching the S-Lites to go along with my new Pilot Sports. So far I have a found a good price on some Hyper Black Motegi SP10s, but I was wondering if anyone one has some suggestions. I also like the R114 JCW rims and they are lighter than the SP10s (about .3 lbs lighter 16.8 vs 16.5). Thanks, and I am looking to spend around $500-600 on the rims.
Old Feb 24, 2015 | 04:18 PM
RDY4TKF's Avatar
RDY4TKF
Check out Tire Rack. They have the Sparco Assetto Gara for about $425 for the set.
Old Feb 24, 2015 | 04:53 PM
cristo's Avatar
cristo
Alliance Member
Enkei Racing PF01 or RPF01 would be lighter (14# or 13.7#) and stronger (MAT technology casting)
than the SP10s or the Sparco A. Garas, but a bit pricier, about $1K for a set of 4.
Old Feb 25, 2015 | 05:42 AM
Saltysalt's Avatar
Saltysalt
I have OZ ultra leggeras, they are really light, the enkei are nice as well. the sparcos are the cheapest price that you are looking for. you wont notice a difference of .3 lbs per wheels. you will definently notice the near 10lbs. I have a very noticeable difference going from my winter wheels (slites) to my ultra leggeras for the warmer months
Old Feb 25, 2015 | 09:40 AM
v10climber's Avatar
v10climber
I would doubt the OEM wheels are that light. Where are you seeing 16.8lbs?
We had the motegis SP10s for a while. They're a solid wheel and we had no real complaints. They're cheap and fairly light. You'll need "tuner" lugs or bolts though because the holes the lug nuts/bolts sit into are really small.
Old Feb 26, 2015 | 05:34 AM
Grizld700's Avatar
Grizld700
If you believe everything you read on the interwebs then THIS would be one source that would corroborate the 16.8. And actually this is showing even less weight!
Old Feb 26, 2015 | 02:23 PM
v10climber's Avatar
v10climber
Ahh that is showing the R114 as a 17x5.5. Awfully narrow wheel. The SP10s you're looking at are probably 17x7. most of the 17x7" OEM mini wheels are in the low 20lb range.
Old Feb 26, 2015 | 08:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check out the NM wheels they car cost effective and clear the JCW brake with no spacers.
Old Feb 27, 2015 | 07:04 AM
cristo's Avatar
cristo
Alliance Member
5.5 has to be a typo.
Old Feb 27, 2015 | 07:20 AM
AndyPWR53's Avatar
AndyPWR53
I don't think it's a typo. The website says they are a winter wheel, whatever that denotes.
Old Feb 27, 2015 | 09:50 AM
cristo's Avatar
cristo
Alliance Member
Yep, you're right as rain ... or snow.
Designed for use with a 185/50/17 winter tire (hard to find).
Old Feb 27, 2015 | 11:04 AM
Grizld700's Avatar
Grizld700
+1 I love my NM wheels. Very light, simple design.
boydie
Sep 13, 2015 05:06 PM
Ladybug-S
Sep 10, 2015 07:08 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
