:: ECS Tuning :: R56/R55 FORGE Motorsport : Gen 2 Thermostat kits : F56 Wheels ||
Old Feb 19, 2015 | 02:31 PM
R56 MINI Cooper S/JCW FORGE Intercooler Resonator Delete Hose
MINI chose to fit a restrictive resonator to the factory intercooler hoses on the R56 Cooper S/JCW. The intention was to reduce engine noise and the recognizable "whoosh" intake sound.
Forge has designed a silicone replacement, freeing up horsepower and torque while better resisting heat and chemical degradation.
The Intercooler Resonator Delete Hose comes in three colors, adding an extra aesthetic dimension to your engine bay.
Smoother interior surfaces enhance airflow, while the silicone material better withstands extreme temperature and pressure.
Fits:
R56 MINI Cooper S / JCW (2007+)
Click HERE for FORGE
MINI R56 R55 R57 Base Thermostat Replacement Kit
Prevent cooling issues before they begin with an ECS Tuning Thermostat Replacement Kit.
The experts at ECS have identified all of the common parts that tend to wear significantly or fail and have assembled a comprehensive kit including all replacement parts for a thorough refresh.
If your MINI has high miles or has an unreliable thermostat, replace all the critical components at the same time for added assurance.
Hot or Cold?
Fits:
R55 MINI Clubman (2008-6/2010)
R56 MINI Cooper (2007-6/2010)
R57 MINI Cooper Convertible (2009-6/2010)
Click HERE for Thermostat Housing kits
MINI R56 R55 R57 JCW Thermostat Replacement Kit
Hot or Cold?
Fits:
R55 MINI Clubman JCW (2009-6/2010)
R56 MINI Cooper JCW (2009-6/2010)
R57 MINI Cooper Convertible JCW (2009-6/2010)
Click HERE For the Thermostat Kits
MINI F56 Cooper Base Genuine Steel Wheels
Genuine MINI steel wheels are arguably the best solution for the enthusiast looking for a practical, affordable winter wheel setup.
The strong metal construction and 5.5” width make for a rugged, highly serviceable arrangement capable of withstanding the rigors of winter weather.
15 x 5.5 , Et46, 5x112 bolt pattern
Real Steel.
Fits:
F56 MINI Cooper Base (2014+)
Click HERE For the Steel Wheels
MINI Fastener Assortment Kit
Avoid finding yourself without a key trim fastener - stock up for good with the Vaico MINI Fastener Assortment Kit.
Designed with the DIY enthusiast or body shop in mind, this assortment comes stocked with clips for fender liners, interior trim, and body mouldings, all in a convenient storage case.
An extremely convenient kit for the discriminating MINI owner, you can now achieve a factory-perfect look instead of leaving crucial interior elements out of sorts.
Fasten the Furious
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible S/JCW (2005-2008)
R53 MINI Cooper S/JCW (2002-2006)
Click HERE for part kit
R55 MINI Clubman S/JCW Forge Silicone Hose Kit
The R55 MINI Clubman/S powerplant is an expertly engineered work of art - there is little room for significant, long-lasting improvement to this engine.
However, replacing rubber and plastic hoses with silicone units has proven over time to result in a longer lasting, better performing engine.
Forge has created a silicone intercooler outlet hose and throttle body inlet hose for your car.
The construction of these hoses better resists thermal and chemical degradation, and with three colors to choose from, better match your engine bay and personal taste.
Forge Ahead!
Fits:
R55 MINI Clubman S (2008-6/2010)
R55 MINI Clubman JCW (2009-6/2012)
**N14 Engines**
Click HERE for Forge Silicone Hose Kit
__________________________________________________ ___________-__
R58 R59 MINI JCW/Roadster Forge Silicone Hose Kit
The MINI Cooper JCW/Roadster powerplant is an expertly engineered work of art - there is little room for significant, long-lasting improvement to this engine.
Forge has created a silicone intercooler outlet hose and throttle body inlet hose for the R58/R59 MINI Cooper JCW/Roadster.
The construction of these hoses better resists thermal and chemical degradation, and with three colors to choose from, better match your engine bay.
Forge Ahead!
Fits:
R58 MINI Coupe JCW (2012-6/2012)
R59 MINI Roadster JCW (2012-6/2012)
**N14 Engines**
Click HERE for Silicone Hose Kit
R56 MINI Cooper Forge Silicone Hose Kit
The R56 MINI Cooper powerplant is an expertly engineered work of art - there is little room for significant, long-lasting improvement to this engine.
Forge Ahead!
Fits: N14 Engines
R56 MINI Cooper S (2007-6/2010)
R56 MINI Cooper JCW (2009-6/2012)
R57 MINI Cooper Convertible Forge Silicone Hose Kit
The R57 MINI Cooper powerplant is an expertly engineered work of art - there is little room for significant, long-lasting improvement to this engine.
Forge Ahead!
Fits: N14 Engines
R57 MINI Cooper S Convertible (2009-6/2010)
R57 MINI Cooper JCW Convertible (2009-6/2012)
Click HERE for Forge silicone
MINI R52 DICE MediaBridge / Silverline Duo By Audiovox
The DICE MediaBridge takes the hassle and aggravation out of playing your favorite audio source through your MINI R52 Cooper Convertible's sound system.
The DICE Media Bridge / Silverline Duo module turns your car stereo into a master control for USB storage drives, IPhone, iPod, or any audio device that can be plugged into the standard audio port.
The unit supplies high-fidelity audio to meet the demands of even the most discerning audiophile.
Putting It All Together
Fits:
R52 MINI Cooper Convertible / S (2005-2008)
Click HERE for Dice Products
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
