No sound from driver side door after replacing door shell
Old Jan 22, 2015 | 09:53 PM
carltdh's Avatar
carltdh
I recently replaced my driver side door (niece backed into my car).
Everything works fine as far as the window, lock, side mirror, and lights go. However, sound from the speakers aren't working. Any thoughts on what could have caused this? More importantly, how can I fix this issue?
Old Jan 22, 2015 | 10:03 PM
TBRoye's Avatar
TBRoye
Either they are not connected or the wires were damaged/broken in the accident. The connector on the back of the speaker may be damaged or broken or the speaker it's self is toast. The door panel is probably going to have to be removed or maybe just speaker, don't know if you can do it from outside of door panel. good luck
Tom
Old Jan 22, 2015 | 10:49 PM
carltdh's Avatar
carltdh
Tom
Speakers were working fine after the accident. I've spot checked all plugs and clips and everything looks to be connected correctly... Unless there's some connector I'm missing... What is the main speaker connector(s) I should be looking at?
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
