Checking for Boost Leak
Old Jan 18, 2015 | 08:46 AM
zcast's Avatar
zcast
Is there a process on the N14 engine to see if you are losing boost to a possible leak? I though there was something about it but I can't seem to find the info on the process. Something like a PVC port you put on the turbo inlet to check? While my nGauge (OBD based) reads I am generating boost (20 psi or so on DNA stage 3) I don't feel like that is actually what I am getting. There is a slight high-piched whine/air hiss that I hear under acceleration (not the typical CAI draw) and I would like to see if I can pinpoint if there is a leak by doing a boost check.
Any ideas?
-Z
Old Jan 18, 2015 | 06:34 PM
oldbrokenwind's Avatar
oldbrokenwind
My last dyno check, the guys connected an air hose to the CAI inlet and added pressure. Leaks can be traced that way, if you have patience and someone else to help. You need to be acrobatic ---
Old Jan 22, 2015 | 02:50 PM
nkfry's Avatar
nkfry
These cars are very temperamental if there is a boost/vacuum leak, but I would say start with checking all the connections of the charge piping for oily buildup, and if that checks out to move onto using a smoke machine to check for air leaks.
I've caught myself thinking there is an issue with my cars, when in reality there is nothing wrong, but being preventive is prosperous in the long run.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
silence2-38554
98
Sep 21, 2016 02:52 PM
johntotah94
Oct 19, 2015 02:20 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Etrain
11
Aug 20, 2015 10:22 AM
Indimanic
Aug 19, 2015 11:08 AM
