:: ECS Tuning :: R53/ R52 Coolant kit | R56+ Blackline Kits | F56 MINI Roof Racks &+
Old Jan 16, 2015 | 02:18 PM
R52/R53 Cooper S/JCW Coolant Expansion Tanks
Continual heat cycling and system debris will crack and eventually stain the expansion tank, also referred to as the coolant recovery bottle.
Aging coolant tanks can cause several problems, including coolant loss, a leaking pressure cap that lowers system pressure, and overheating the engine.
Now you can address all of these issues at once--or head them off before they become bigger problems--with a new coolant expansion tank for the R52/R53 MINI Cooper.
The direct-fit tanks come ready to install with a new pressure cap.
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for Coolant Kits
F56 Roof Rack Base Bars
Rack 'em up with an original MINI roof rack base. This OEM original clamps directly to factory-installed roof railing on your MINI. Once installed, the rack accepts a range of accessories, both MINI-original and aftermarket, including RockyMounts.
Order a complete OE base bar kit that includes keys and installation tools.
Treble Your Fun; Add a Little Base
Fits:
F56 MINI Cooper / S (2014+)
*Only with installed roof rails
Click HERE for the roof rack set
R50 R52 R53 Aero Grille Kit
The Genuine MINI Aero Grille Kit is a subtle but powerful aesthetic upgrade for your R50/R52/R53 Cooper.
The matte black finish adds a performance-oriented dimension to the front of your MINI, and because the part is Genuine MINI, matching the MINI Aero style comes naturally.
The single kit comes with both the upper and lower Aero Grille.
OEM assurance
Fits:
R50 MINI Cooper (2002-2006)*
R53 MINI Cooper S / JCW (2002-2006)*
R52 MINI Cooper Convertible / S / JCW (2005-2008)*
Lower section requires slight modification to fit for Non Aero bumpers.*
Click HERE For the Grille Kits
R55-R57 MINI Viaco Lower Control Arm Bushings
Is your MINI Cooper making noises over bumps, or does your steering feel loose and less responsive than it once was? The control arm bushings are a big cause of front suspension problems, and the only remedy is to replace them.
This kit was built by the experts at ECS Tuning, and it includes both lower control arm/wishbone bushings. Both bushings are already pressed into their brackets, so you won't have to worry about renting or buying the equipment needed to press the bushings in. Fix your front suspension issues today with this kit from ECS Tuning.
The Best Remedy
Fits:
MINI R56 Cooper /S (2007+)
MINI R55 Clubman /S (2008+)
MINI R57 Cooper Convertible /S (2009+)
MINI R58 Coupe' /S (2012+)
MINI R59 Roadster /S (2012+)
Click HERE for LCAB kit
Gen 2 R56 Trunk Release Kit
Are you having trouble getting into your trunk?
ECS Tuning has the solution with this Trunk Release Kit, which includes the trunk lid with internals (available in both Primer and Chrome), and the lock mechanism. This kit will allow you to fix the rear hatch button grip with an easy, all-in-one kit.
Available in both Primer and Chrome, if necessary the primed handle can be replaced by your painted handle already on your vehicle.
Fits:
R56 MINI Cooper Hardtop 2007+
Click HERE for kits
R52/R53 Mishimoto Radiator Hose Kits
The MINI R52/R53 relies heavily on adequate engine cooling to make reliable power. Any leaking, bending, or warping of the hoses that hold cooling fluid will result in a considerable loss of performance & driveability.
Mishimoto now offers a full Silicone Coolant Hose Kit for the MINI, drastically improving durability over the factory hose arrangement, while eliminating flow restrictions.
Molded to exact OEM specifications, the improved design better withstands heat & pressure, resisting swelling and electro-chemical degradation for a longer service life.
Heat Check
FIts:
Click HERE for silicone hose kits
__________________________________________________ ___________-__
R58/R59 Blackline Trim Kits
Little guys are tough. It's a big world, so they have to be. A Blackline Trim kit will give your R58/R59 MINI a tough look in keeping with its tough personality.
MINI Blackline trim is made of durable plastic, with a special coating that is far tougher than spray paints or plastic coatings. These trim kits are Genuine MINI products so you can expect factory fit and finish and an easy installation.
Blackline trim kits will toughen up your MINI without sucker-punching your wallet.
Black eyed, please.
Fits:
R58 MINI Coupe'/S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for kits
R55/R56/R57 Blackline Trim Kits
Little guys are tough. It's a big world, so they have to be. A Blackline Trim kit will give your R55/R56/R57 MINI a tough look in keeping with its tough personality.
Black eyed, please.
Headlights Fit: MINI
R55 MINI Clubman 2008+
R57 MINI Cooper Convertible 2009+
Taillights Fit: MINI
Click HERE for kits
1chaos52
Aug 24, 2015 01:28 PM
Aug 7, 2015 07:12 AM
Aug 7, 2015 07:11 AM
