Turbo Oil Line Fix from WMW
Old Jan 12, 2015 | 08:07 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Way Motor Works has the fix for your turbo oil line failures. If you have a turbo MINI Cooper S make sure when your doing your service that you check the top oil feed line for the turbo. The factory oil line as a small seal in it that over time drys out and will leak oil on the top of the turbo. Letting it leak can be a major issue as the turbo can loose oil or worse case the oil can build up on the manifold and catch fire. If you need to replace it check out our WMW stainless turbo oil line kit. It replaces the oil feed line with a stainless line like a brake line, and has flair fitting to seal with NO rubber in it to fail. A great addition to fix a leaky line, or prevent a future failure.
Kimolaoha
Jul 5, 2023 01:04 PM
W0TM8
Dec 19, 2019 07:50 AM
rckrzy1
Aug 26, 2015 09:12 AM
PelicanParts.com
Aug 14, 2015 11:07 AM
azntaiji
Aug 13, 2015 03:24 PM
