:: ECS Tuning :: *MINI* Roof Racks \/ Pipercross SALE \/ ECS & Ziza Holiday SALE
Old Dec 3, 2014 | 02:32 PM
MINI R55 Clubman '08 Roof Rack Kit
Rack 'em up with an original MINI roof rack base bar kit. This OEM original clamps directly to factory-installed roof railing on your MINI. Once installed, the rack accepts a range of accessories, both MINI-original and aftermarket, including RockyMounts.
Order a complete OE base bar kit that includes keys and installation tools.
Treble Your Fun; Add a Little Base
Fits:
R55 MINI Clubman (2008+)
R55 MINI Clubman S (2008+)
R55 MINI Clubman JCW (2009+)
Click HERE for Roof Racks
MINI R56 Genuine Roof Rack Base Bars
Rack 'em up with an original MINI roof rack base. This OEM original clamps directly to factory-installed mounting points, pre-installed below the roof edge guards of your MINI. Once installed, the rack accepts a range of accessories, both MINI-original and aftermarket, including RockyMounts.
Order a complete OE base bar kit that includes keys, installation tools (even tweezers to make pulling the trim easy for you!), and trim plugs for when the rack takes a break and stays at home.
Fits:
R56 MINI Cooper (2007+)
R56 MINI Cooper S (2007+)
R56 MINI Cooper JCW (2009+)
Click HERE for the roof rack kit
R53 Cooper S Pipercross Filter
Your R53 MINI Cooper S is a masterpiece of engineering that pumps out power with incredible fuel efficiency. Sophisticated as it is, however, it still needs thousands of gallons of air to burn a single gallon of fuel.
Don't settle for stock. Pick Pipercross filters, designed with a progressive foam filter media that promotes air flows, without compromising filtration efficiency.
Track tested for the last quarter century, Pipercross Performance Filters are durable, cleanable, and tough enough to protect your engine for years and thousands of miles.
Pipercross Perfoamance Filters
Fits MINI:
R53 MINI Cooper S (2002-2006)
*non JCW Kit or Airbox
Click HERE For the Pipercross
R50/R52 ( NON S ) Pipercross Filter
Your R50/R52 MINI Cooper is a masterpiece of engineering that pumps out power with incredible fuel efficiency. Sophisticated as it is, however, it still needs thousands of gallons of air to burn a single gallon of fuel.
Fits:
Square Filter Fits:
R50 MINI Cooper up to 7/2004 - all transmission types
R50 MINI Cooper /R52 MINI Cooper Convertible (Base) from 7/2004 - automatics
Triangle Filter Fits:
R50 MINI Cooper /R52 MINI Cooper Convertible (Base) from 7/2004 - manuals
Click HERE for Pipercross on Sale
R55-R59 MINI ECS Strut Tower Plates
The strut tower for the MINI Cooper was designed to adequately support the stresses and forces encountered during typical daily driving.
Aging models or vehicles that are routinely pushed past the limitations of the chassis oftentimes experience strut tower deformation, compromising the crisp and responsive handling that defines every MINI.
Machined from 15mm thick 6061-T6 aluminum, ECS Strut Tower Plate Kits eliminate the prospect of tower mushrooming while improving chassis rigidity.
ECS Smart and Simple
Fits:
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for ECS Strut Tower Plates on Sale
R60 MINI Countryman ECS Wheel Spacers
Wheel spacers are a great way to get the look you want from your wheels. Set up a more aggressive stance by pushing the wheels out from the body, or as a cure for wheel rubbing if you added a quality lower suspension kit. ECS offers a wide variety of sizes to give you the exact look you need. All spacers are made from a high quality aluminum to keep weight to a minimum and resist corrosion.
GO WIDE -ER!
Fits:
R60 MINI Countryman / S / SX / JCW
Click HERE for ECS Wheel Spacers kits on Sale
R50/R52/R53 ECS Strut Tower Plates
ECS; Smart and Simple
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for ECS STP kits on Sale
GEN2 ECS Wheel Spacers
GO WIDE -ER!
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R58 MINI Cooper Coupe' /S/JCW (2012+)
R59 MINI Cooper Roadter /S/JCW (2012+)
Click HERE for the ECS Wheel spacer kits
MINI R56 Ziza LED Interior Lighting Kits
LED bulbs are a stunning revolution for the world of automotive lighting and it’s easy to see why.
LED bulbs are vastly superior to stock bulbs, as they have a higher light output and are far more efficient. Installing these Ziza LED bulbs is a breeze, as you just pop out the old bulb and insert a new one, giving you incredible lighting in a matter of moments.
This kit will transform your entire interior to bright white light.
Stunning Light
Fits:
R56 MINI Cooper /S/JCW (2007- 8/2010)
Click HERE for the Ziza LEDs
MINI R56 '11+ Ziza LED Interior Lighting Kits
Stunning Light
Fits:
R56 MINI Cooper /S/JCW (08/2010+)
cub4bearindiana
Aug 25, 2015 06:49 PM
Aug 7, 2015 07:12 AM
Aug 7, 2015 07:11 AM
