Brakes grinding
Old Nov 21, 2014 | 08:24 PM
HyTech's Avatar
HyTech
From: Part year in Portland OR, part year Kalamazoo MI
Brakes grinding
I don't know if this is a stock problem. Came down a two mile, 6% grade hill the other day and was treated to quadraphonic brake grinding. I couldn't imagine that all four brakes would start grinding at the same time. After the brakes cooled I felt them and there were no grooves or surface damage. I did feel tall rust ridges around the inner and outer circumference. I theorize that the heat from the braking made the discs expand slightly making the rust contact the pads. There has been no grinding since.
Old Nov 22, 2014 | 12:04 AM
Eric_Rowland's Avatar
Eric_Rowland
Not really common, but I can see things expanding when heated up like that. Ridges in and out are common (oem rotors are soft.) If the pads are all at serviceable levels, I'd let it ride.
Note that MINI suggests/requires rotors to be changed with pads.
Old Nov 22, 2014 | 12:10 AM
bmwr606's Avatar
bmwr606
and do not use the brakes on a downhill to control speed, downshift and use the engine
Old Nov 23, 2014 | 05:59 AM
HyTech's Avatar
HyTech
Once they cooled the grinding was gone. I don't drive it a lot because I ride my scooter as much as I can. So, it sits and the rust grows here in the wet northwest. I'll take the wheels off and take all that stuff off.
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 3, 2015 03:01 PM
Sep 2, 2015 11:15 AM
