:ECS Tuning: Powerflex Bushing SALE |* Oil Service Kit | ECS Geomet Rotors R61
Old Nov 11, 2014 | 01:01 PM
MINI R58/R59 S JCW Powerflex Performance Bushings
The function of your suspension is highly dependent upon the quality of the bushings that each component pivots or rotates on.
The R58/R59 Coupe/Roadster has a perfected suspension geometry; worn bushings widen clearances and decrease suspension articulation.
Powerflex Performance Polyurethane Front Control Arm Bushings are made out of durable polyurethane for longevity and steering feel.
Tighten Up
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for poweflex bushings
MINI R50 R52 R53 Oil Service Kits
A complete oil change kit with factory approved parts and lubricants is a wise investment for the discriminating MINI owner.
Regular oil changes don't just flush away abrasives, acids, and moisture, they restore lubricity, and replenish the additive packages that protect close-tolerance engine parts from chemical attack and corrosion.
Our original equipment kits also include a fresh drain plug with bonded seal for added peace of mind and a drip-free garage floor.
At Your Service
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S/JCW (2002-2006)
R52 MINI Cooper Convertible/S/JCW (2005-2008)
Click HERE for the Oil Change Kits
MINI Gen 2 Forge Blow Off Adapter
Forge has created a simple, easy to install part that allows your factory boost solenoid to vent excess boost to the atmosphere, much like a blow-off valve.
The Blow Off Adapter simply bolts in between the electrical solenoid and turbocharger housing with three Allen bolts. Instead of recirculating excess charged air back into the turbo, the air is vented into the atmosphere through outlets in the adapter.
The result is that hot air is not allowed to be reused by the turbo while the critical function of a diverter valve is retained, keeping the turbo spooling and reducing lag.
Forge Ahead
Fits:
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE For the FORGE
MINI R50 R52 Crank Pulley ( Cooper : NON S )
If your MINI R50/R52 crankshaft pulley is rusted or overly worn, you may experience premature accessory belt wear, causing unexpected engine problems.
Your crank pulley must also be adequately balanced for it to sufficiently ameliorate engine pulsations for smooth power delivery.
ECS now offers OEM MINI Crankshaft Pulleys for your car.
The rotationally balanced factory unit is a direct replacement part that will restore engine smoothness and extend accessory belt life.
Crank it Up
Fits MINI:
R50 Cooper (2002-2006)
R52 Cooper Convertible( 2005-2008 )
Click HERE for crank pulley .
Mini R61 Paceman S/SX ECS GEOMET® Brake Rotors
ECS GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits and reduce fade, select a drilled and slotted ECS GEOMET® rotor.
Cross-drilling dissipates heat faster for better braking and reduced fade.
Slotting cleans the pads by moving water, gasses, and contaminants away from the pad/rotor contact surface to further enhance braking performance.
Stopping Never Looked So Good
Fits:
R61 MINI Paceman S (2013+)
R61 MINI Paceman SX (ALL4) (2013+)
Click HERE for ECS Geomet kits
MINI R56-R59 Hood Release Kit
A sticking or broken hood cable is not only a pain when it comes time to service your engine; the issue also presents a significant risk to your driving safety.
Over time, corrosion can cause the release to seize, potentially making it impossible to even open your hood.
ECS now offers the genuine MINI Hood Release Kit, including each part required for the complete job.
The Complete Solution
Fits:
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe /S/JCW (2012+)
Click HERE for the hood release kit
MINI Gen2 Oil Service Kits
The best oil for your MINI? Clean oil. Regular oil changes with a quality filter cartridge are cheap insurance against costly breakdowns, and the best way to keep your MINI healthy.
Now you can perform this essential service yourself and save big with MINI oil change kits that contain an OEM filter cartridge with drain plug, plus your choice of name brand engine oils that meet BMW LL-98 and BMW LL-01 standards.
Spend a little up front and head off major repairs, down the road.
Drain Your Oil, Not Your Wallet
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
Click HERE for ECS Oil Change Kits
MINI R50/R53 Bentley Service Manual
Guesswork is expensive. It leads to costly repair errors that compromise vehicle safety. Talented pro-sumer or repair professional, you need accurate vehicle data and specifications.
That's why ECS is happy to offer an entire inventory of Bentley manuals, a reliable, respected source of repair data for many European vehicles.
This comprehensive source of info on your MINI has been carefully edited and illustrated. A worthwhile investment.
At Your Service
Fits :
R53 MINI Cooper S / JCW (2002-2006)
Click HERE for the Bentley Manual
silence2-38554
Nov 12, 2015 09:39 AM
minicoclub
Nov 11, 2015 07:25 AM
O4mcs
Aug 10, 2015 10:22 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
