'03 S Lites on '08 MC Base with TPMS?
Old Nov 4, 2014 | 08:27 AM
busterhax's Avatar
busterhax
I couldn't find any concrete information on the web pertaining to the subject.
I have a 2008 r56 mini cooper base. I found some 2003 S-Lite wheels I'd like to use. Does anyone know if the TPMS sensors from my 08 will work fine with the 2003 s-lite wheels?
Old Nov 5, 2014 | 06:23 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
see Post #9
https://www.northamericanmotoring.co...er-wheels.html
S-lyte wheels were for R53 MINI's 12mm wheel bolts while the newer R56 MINIs came with 14mm bolts. Apparently the S-lytes will be OK. If not drill out the holes.
Yes the TPMS will fit the older wheels but you may need a longer sensor attaching screw as mentioned.
Old Nov 5, 2014 | 07:42 PM
busterhax's Avatar
busterhax
Wrong. They still work with fatter lugs. That is a myth.
Old Nov 5, 2014 | 08:47 PM
Joeygonz's Avatar
Joeygonz
I once fitted a set of S-Lites with OEM lug bolts and TPMS'. Everything worked fine and used it for many months.
Waszak
Oct 21, 2017 05:55 PM
vargasgal
Sep 17, 2015 10:02 AM
shahriar35
Sep 14, 2015 11:53 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
