:: ECS Tuning :: Paceman " Black Line " Trims | Huf TPMS Sensors | JCW Wheel Sale !
R61 MINI Black Line Headlight & Tail Light Trim Kit
Genuine MINI 'Black Line' Headlight and Tail Light Trims bring a subdued black look to your factory headlight chrome or black housings and tail light red housings.
The kits include both the left and right side tail light or headlight trims, allowing you to refresh look of your MINI R61 Paceman in a single kit.
And because the parts are genuine MINI, fitment and quality are guaranteed.
OEM Style
Fits:
R61 MINI Paceman Base / S / SX / JCW (2013+)
Click HERE for Black line trim kits
MINI R55 R56 R57 Tire Pressure Sensors
Tire pressure monitoring is a convenient feature - when it's working properly.
Too often, when the tire pressure light illuminates in your MINI, the cause has nothing to do with the pressure inside your tire.
A worn tire pressure sensor is usually the culprit, sending false readings to the ECU, causing unnecessary concern to the driver.
ECS offers replacement Tire Pressure Sensors, sold individually or as a set of four. After installation, simply navigate to the TPM screen to clear the light from your dash.
One Less Dash Light
Fits:
R56 MINI Cooper /S/JCW (2008-9/2009)
R55 MINI Cooper Clubman /S/JCW (2008-9/2009)
R57 MINI Cooper /S/JCW (2009-9/2009)
Click HERE for the Huf sensors
MINI F56 Hella Twin Supertone Horns
Hella Twin Supertone Horns are now available for your MINI.
These horns are characterized by their strong penetrating and concentrated sound, making anyone within a sizable distance aware of your presence.
All of Hella's horns are constructed with durability in mind from impact resistant plastic and feature a 400 Hz low tone and 500 Hz high tone horn.
All kits include the horns, relay, and mounting brackets.
BE HEARD.
Fits:
F56 MINI Cooper/S (2014+)
Click HERE For the Hella horns
R60/R61 MINI Huf Tire Pressure Sensors
ECS offers replacements sold individually or as a set of four. After installation, simply navigate to the TPM screen to clear the light from your dash.
Also great as a set of four when upgrading or changing to new wheels.
One Less Dash Light
Fits:
R60 MINI Countryman Base / S / SX / JCW (2011+)
Click HERE for Huf Sensors kits .
MINI Cooper R50+ R105 JCW Wheel & Tire Sets Of Four
ECS now offers a superbly matched wheel and tire set from legendary MINI tuner JCW.
The 18-inch double-spoke wheels are finished in either matte black or bright silver and are wrapped with Pirelli P Zero asymmetrical Run Flat High performance tires.
The combination not only perfectly complements any MINI's styling, but offers fitment, quality, and performance only possible through JCW.
The balanced wheels with MINI JCW center caps arrive ready to mount - just fill with air and drive.
JCW 4 Piston Brake kits will need 5mm spacer.
The Works
Fits:
R50/R52/R53 Cooper/S/JCW (02-08)
R56 Cooper /S/JCW (07+)*
R55 Clubman /S/JCW (08+)*
R57 Convertible /S/JCW (09+)*
R58 Coupe /S/JCW (12+)*
R59 Roadster /S/JCW (12+)*
* Fits up to 9/2009 with TPMS sensor included:
9/2009+ will need to swap sensor out to ES2763259
Click HERE for wheel & tire kit .
R60/R61 MINI R125 Tunnel Spoke Wheels
The R125 Tunnel Spoke Wheel was designed for MINI by Ronal, an OEM wheel supplier recognized for unmistakable design and innovation.
The dished, wide 5-spoke design is an excellent fit for the R60 Countryman and R61 Paceman, complementing these cars' styling perfectly.
The entire exposed wheel surface is painted matte white while featuring machined turned edges, giving your MINI a sporty look reminiscent of the GP-type style 4-spoke wheel.
Genuine MINI Taste
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for the wheel kits
MINI R50-R53 Power Steering Replacement Lines
The power steering lines fitted to the MINI R50/R52/R53 have been known to leak, potentially causing steering failure.
Instead of replacing parts as they fail, the wiser, most economical approach is to change out each part in one servicing.
The ECS assembled Power Steering Line kits include each part required for a complete refresh, including the power steering return and suction lines, all hose clamps, hollow bolt, and all sealing o-rings.
Steer Clear of the Big Issues
Bulk Up
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Click HERE for p/s line sets
MINI Gen2 S/JCW N14 Forge Blowoff Valve Kits
Ready to blow off a little steam? Get Forge under your hood.
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
Aluminum housing. Faster Response. Works and plays well with engine management systems.
Forge Forward
Fits MINI:
R56 Cooper S (2007-2010) / JCW (2009-2012)
R55 Clubman S (2008-2010) / JCW (2009-2012)
R57 Cooper Convertible S (2009-2010) / JCW (2019-2012)
R58 Coupe' JCW ( 2012)
R59 Roadster JCW ( 2012)
Click HERE for the Forge kits
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
