For Sale: r53 parts
For Sale: r53 parts
Selling the Mini :( and therefore getting rid of parts.
Factory Front Aero Grill kit. Both Upper and middle grills. Fit's a lot of Mini's including 02-06 R50 & R53, 05-08 R52. Opened but never used, still in box.
$75
Genuine MINI illuminated door sill strip - 51470302686. BNIB. Straight from the dealer. *Note this is not a picture of the actual item, which is a just a box*
$225
OEM exhaust header. ~70k miles. Taken off my healthy car that passed emissions. Good condition.
$175
OEM exhaust header. ~90k miles. Bought from another forum member. Had planned to cut out the cat for a custom project but times changes. Ok condition. Some minor rust.
$100
Madness Motorworks R53 header. I'm selling the Mini otherwise I would have this great header installed. Flex joints can go bad but I just bought a new flex joint and had it installed by the Madness shop. I'm also including the test pipe and a a special BMW expansion joint (pre-installed). This allows the test pipe to be easily installed with whatever exhaust in a catless setup which means this is plug and play which saves you a lot of headache. The test pipe also has an extra welded o2 bung installed for an AFR sensor and I'll include an o2 plug in case you don't have an AFR. The aftermarket CAT seen will not be included.
$500
OEM brake rotors. ~75k miles.
$50
OEM Camshaft gear.
$30
All prices are for local exchange. I'm fine with traveling to a middle point if necessary. I'm in SW PDX.
Happy motoring
$75
$225
$175
$100
$500
$50
OEM Camshaft gear.
$30
Happy motoring
