Cleared 2096 Code With New Exhaust Gasket
Old Oct 16, 2014 | 02:20 PM
ericfreeman's Avatar
ericfreeman
A while back I picked up a P 2096 code along with the Engine Service Light. I have an aftermarket exhaust that I fitted several years ago (at about 60,000 miles), using their flange gasket. I've been hearing a slight exhaust leak on occasion and decided to replace the flange gasket near the rear oxygen sensor. I currently have 124,000 miles on the car.
When I jacked up the car and ran the engine, I couldn't feel any exhaust leakage from around the flange but there was a bit of water dripping out of the joint (car had just been started after sitting overnight). When I removed the two bolts the gasket basically fell apart. It was one of those foil-type gaskets with a thin layer of insulation in between. Much less robust than the OEM gasket, which I had on-hand to install. Fitted the new OEM gasket, tightened the bolts and could immediatly tell that the exhaust leak was gone. Now, after 4 days of driving to work, the Check Engine light went off!!
I'm very happy that all I had to do was replace the flange gasket: no trips to the dealer or specialty shop, just a new gasket. Definitely worth looking into if you have an aftermarket exhaust with supplied gasket or just have enough miles to have caused the original gasket to have deteriorated.
Eric
David.R53
Sep 1, 2015 06:49 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Aug 19, 2015 12:51 PM
wind715
Aug 11, 2015 07:56 AM
ti22fjc
Aug 9, 2015 05:49 PM
