Sprint Booster for your 2013+ MINI Cooper!
Old Oct 16, 2014 | 02:08 PM
Mini Mania's Avatar
Upgrade your MINI's performance in 10 minutes or less!
NEW! Switch between factory, sport and race settings for your MINI with Manual Transmission!
The new Sprint Boosters now come with a plug n' play selectable switch. The selectable switch can be located anywhere the driver chooses with the use of double sided tape. The driver will be able to choose between 3 acceleration programs by pressing the LED button: factory, sport and race. Compatible with the following models:
2013 R56 MINI Cooper and Cooper S Hatchback
2013-2014 R55 MINI Cooper and Cooper S Clubman
2013-2014 R57 MINI Cooper and Cooper S Convertible
2013-2014 R58 MINI Cooper and Cooper S Coupe
2013-2014 R59 MINI Cooper and Cooper S Roadster
2013-2014 R60 MINI Cooper and Cooper S Coountryman
2013-2014 R61 MINI Cooper and Cooper S Paceman
The Sprint Booster for the new 2014+ F56 MINI Cooper and Cooper S Hardtop is currently under development.
Sprint Booster puts an end to your MINI's poor performance once and for all.
This isn't just something that you feel when you get to top end speed. You feel the difference in your daily driving... and it makes driving fun again.
We're offering a bulletproof 30-Day Money Back Guarantee! Since you need to feel the difference to believe it, you get to test-drive Sprint Booster for 30 Days, risk free!
What is Sprint Booster?
Since 2000, auto makers have replaced responsive cable throttle systems with the cheaper electronic versions. Unfortunately, they've robbed your MINI of its performance.
Sprint Booster not only corrects this problem, it actually improves your throttle response. It unlocks your MINI's potential, creating a smoother, more powerful ride.
What happens in your MINI when you hit the gas?
Usually, you get a full second of delay before you start moving. Sprint Booster eliminates this... you get a quicker acceleration from a stop.
This not only makes your MINI more fun to drive, it also makes it safer. It's easier to avoid collisions when you don't have this delay.
After you install Sprint Booster, you feel a huge difference the first time you hit the gas.
Sprint Booster gives you:
  • Quicker acceleration
  • Faster passing
  • Responsive uphill driving
  • Quicker gear changes
  • Easier rev matching
The word is out on Sprint Booster
Check out these reviews on the forums-
"A must have!" (CrossFireForum.org)
"Awesome!" (BenzWorld.org)
"Ridiculously easy to install." (MBworld.org)
Note:
It is normal for the light to stay on after you turn off the ignition. This is caused by the residual power in the circuits when the car is shut down. The reason it stays on so long is the LED is an extremely low power device, and it takes time for this power to bleed off. There is no cause for alarm as this is an extremely low power dissipation and the light does go off.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
