R50/53 The Timing Chain is ALIVE!!!
Old Oct 7, 2014 | 06:52 PM
rcolina22's Avatar
rcolina22
So I've been getting the damn death rattle for about a month roughly. I changed the tensioner and still the noise is still there. So, then I decided to operate. After about an hour of somewhat easy work, I reached the timing chain. Is there anything you guys would recommend I do to see if it is the chain and not something else? I do not have the tool to take it apart. R53 incase you were wondering
Old Oct 7, 2014 | 08:51 PM
AudioNToxication's Avatar
AudioNToxication
If you were still getting the noise it could be that the plastic part of your chain guide dropped into the oil pan. That's what mine did.
Old Oct 8, 2014 | 04:45 AM
JABowders's Avatar
JABowders
Veteran: Army
+1 the Chain Guide may have started to come apart on you...
It doesn't happen all the time, but it happens.
Motor on!
Old Oct 8, 2014 | 09:24 AM
rcolina22's Avatar
rcolina22
So I looked at it a little closer last night. it seems, the tensioner rail is split in two for a good 4 inches. I'm not a professional, by any means, but I assume that's the problem. The question now, can I uninstall the rail without removing the whole thing?
Old Oct 8, 2014 | 10:09 AM
ThickFREAKness216's Avatar
ThickFREAKness216
I had the same issue, my guides were cracked. The short answer is yes you can replace the guides without removing the whole thing. However, if you have plastic down in your oil pan you will need to get that out by dropping the pan. Be careful you don't mess up the chain/sprocket position and lose timing.
Good luck!
Old Oct 8, 2014 | 08:45 PM
AudioNToxication
If you pull the guides from the top be sure not to let the chain move and skip teeth. If you are missing plastic, definitely pull the oil pan. If the bits are small they will get sucked into the pickup and reduce flow of oil, and thats really bad.
Old Oct 8, 2014 | 08:50 PM
rcolina22's Avatar
rcolina22
There was a piece about 1/2in wide, hanging from the guide itself. So yes, as a precautionary measure, I will look in the oil pan. Thank a lot guys!!
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
scottrn
Aug 22, 2015 07:26 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
