:: ECS Tuning :: KONI FSDs Gen1 & Gen2 | SPC Control Arms kits | F56 Blackline Trim !
Old Sep 22, 2014 | 12:58 PM
MINI R50 Koni FSD Shocks & Struts
KONl shock absorbers with Frequency Selective Damping (FSD) technology, have been specifically designed for the MINI R50, representing the ultimate in comfort and road-holding.
The purely mechanical shocks and struts are independent of electronic control components, making installation easier and product life significantly longer.
KONl FSD suspensions contain an added special valve that controls a parallel oil flow next to the piston, dramatically improving ride quality.
And by retaining the factory ride height, your MINI's wheel fitment & stance will remain unchanged.
Slick Technology
Fits:
R50 MINI Cooper Base (3/2002-2006)
Click HERE for KONI FSD R50
R60/R61 MINI Adjustable Rear Control Arms
For track-ready cars like the R60 Countryman and R61 Paceman, suspension adjustments yield huge gains in handling characteristics.
SPC Performance Adjustable Rear Control Arms are an excellent investment for the MINI owner looking to dial in a more aggressive camber specification, keeping the tire contact patch more parallel with the road surface during hard cornering when traction is most needed.
The beautiful silver-anodized finished arms coupled with SPC "Red" nuts provide a full +/- 4.0 degrees of rear camber adjustment, giving you needed control over this critical parameter.
Dialed in Performance
Fits:
R53 MINI Cooper S / JCW (3/2002-2006)
Click HERE for the SPC Control Arms kit
R55/R56/R57 MINI Cooper Koni FSD Shocks & Struts
Many MINIs have logged a ton of miles by now, and most have road-weary suspension dampers. KONI struts and shocks are always a favorite replacement choice for enthusiasts, since they add a blend of sporty handling and comfort that is unavailable in stock-shocks tuned to match OE ride quality.
KONI fine tunes their shocks and struts by application, refusing to take a "one-size-fits-all" approach used by lesser manufacturers.
KONI shocks and struts are a durable performance choice for stock cars.
Move Up: Not Over
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for KONI FSDs kit .
R50 R52 R53 MINI SPC Rear Control Arms
For track-ready cars like the R50, R52, R53, suspension adjustments yield huge gains in handling characteristics.
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible / S / JCW(2005-2008))
Click HERE for SPC Control Arms kit .
R50/R53 Hood Release Kit -6/2002
A sticking or broken hood cable is not only a pain when it comes time to service your engine; the issue also presents a significant risk to your driving safety.
Over time, corrosion can cause the release to seize, potentially making it impossible to even open your hood.
ECS now offers the genuine MINI Hood Release Kit, including each part required for the complete job; Bowden cables, left and right side locking latches, and a hood unlocking lever.
The Complete Solution
Fits:
R50 MINI Cooper ( Up to 6/2002)
R53 MINI Cooper S / JCW ( Up to 6/2002)
Click HERE for MINI Hood Release Kits .
MINI R58/R59 Ziza LED License Plate Bulb Kit
You won't believe the difference an LED lighting package makes on your car until you see it with your own eyes. LED illumination is a far brighter and friendlier light, crisp and clean, especially when compared to the dingy yellow glow from conventional filament style bulbs.
Ziza lighting is proud to introduce LED license plate bulbs for your MINI that will not cause a "bulb out" warning. These are direct replacement bulbs that install in minutes, there is no need to wire up fancy resistors or rework your factory wiring to get them functioning properly.
Brighter is Better.
Fits:
R58 MINI Coupe' / S / JCW (2012+)
R59 MINI Roadster / S / JCW (2012+)
Click HERE for the Ziza LED kit
MINI R61 Paceman GEOMET® Brake Rotors
ECS GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits for better braking, select a slotted ECS GEOMET® rotor. Slotting cleans the pads by moving water, gasses, and contaminants away from the pad/rotor contact surface.
To prevent rust pitting and corrosion damage, ECS GEOMET® rotors are sprayed with a special water-based solution, then heated to cure the coating and remove all oil residue remaining from the manufacturing process.
Prevent rust pitting and corrosion damage.
Fits:
R61 MINI Paceman Base (2013+)
Click HERE for ECS Geomet Rotors.
MINI F56 Black Trim Rings
Little guys are tough. It's a big world, so they have to be. A Blackline Trim kit will give your F56 MINI a tough look in keeping with its tough personality.
MINI Blackline trim is made of durable plastic, with a special coating that is far tougher than spray paints or plastic coatings. These trim kits are Genuine MINI products so you can expect factory fit and finish and an easy installation.
Blackline trim kits will toughen up your MINI without sucker-punching your wallet.
No More Bling
Fits:
F56 MINI Cooper / S (2014+)
Click HERE for the F56 HL and TL trims
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
