Suspension how to adjust alta endlink to level the sway bar?
Old Sep 15, 2014 | 09:38 PM
marvinclick's Avatar
marvinclick
just installed alta front and rear endlink together with my Tein suspension.
knew should adjust the endlink length in order to level the sway bar for a lowered car, but found the alta looks same long as stock ones, which cannot make my sway bar back to normal angle, leveled.
anyone can help me or how you adjust them?
thanks a lot!
Old Sep 16, 2014 | 08:00 AM
v10climber's Avatar
v10climber
Loosen the two lock nuts at the top and bottom of the endlink. Then turn the center section to make it longer/shorter.
If you're happy with your ride heights and alignment then you'll also want to remove the preload from the swaybar. Put the car on ramps or something so that both wheels (either front pair or rear pair) are loaded. Then get under there and adjust the swaybar endlink so the swaybar isn't preloaded. You only have to mess with one endlink. Loosen the lock nuts and twist the center section all the way one way until it "binds". Then count the turns as you turn it back the other way until it "binds". Then go back the other way half the amount of turns you just counted.
ebowling
90
Aug 4, 2019 09:15 AM
Mini7
Feb 2, 2016 07:52 PM
BRracing
Dec 22, 2015 09:25 AM
minimofo
Sep 9, 2015 10:29 AM
