Engine hesitation. Please help
Old Sep 11, 2014 | 07:12 PM
Johncooperdoeswork's Avatar
Johncooperdoeswork
Hi all. I'm not too good with engines so please forgive me. I just replaced my John Cooper Works cold air intake filter and accidentally pulled out the vacuum tube without noticing it and drove it for a day and a half quite hard. I Realized something was wrong and put the vacuum to back on. Now my engine hesitates when shifting in the low gears as soon as I hit the throttle for about half a second then power resumes. I have a 2005 mini Cooper S John Cooper Works.
Old Sep 12, 2014 | 06:53 AM
nkfry's Avatar
nkfry
Follow the vacuum line down to the bypass valve and see if you also pulled the line from the bypass valve off.
If you are sure there are no vacuum leaks, reset the adaptations, as the car will learn around having vacuum leaks.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 12, 2014 | 12:35 PM
Johncooperdoeswork
I should mention that this does not happen on every shift.
Teh
Jun 13, 2018 02:59 PM
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
