Vibrations at 2000 rpm
Old Aug 26, 2014 | 06:15 PM
dlbrtj6's Avatar
dlbrtj6
Good evening all, first time writing on the forum, however, learned a lot over the past few months from reading others. I have a 2002 MCS and have a vibration when the rpm's hit around 2300. It is strong enough that when you look in the rear mirror, you can't make out the car behind you. I have already changed out the engine mounts and transmission mount. What other suggestions do you all have? I would love to resolve this instead of going to the dealer. Thank you all.
Old Aug 26, 2014 | 07:44 PM
DesertDog's Avatar
DesertDog
Did you check your crank pulley?
Old Aug 26, 2014 | 07:59 PM
dlbrtj6's Avatar
dlbrtj6
No, I haven't looked at that. The dealer said that if that was bad, it would make a rattle noise and I would probably smell rubber. I was looking at the exhaust brackets today, but, can't really tell if they are bad. They look good. When I supported the engine to install the new transmission mount, could something have broken that could now be causing the vibration?
Old Aug 31, 2014 | 06:44 AM
fastzombie's Avatar
fastzombie
I am going to replace my crank pulley with an ATI Crank Pulley from Way Motor Works. I have heard and read that the stock pulley can begin to have the interior rubber come apart that leads to increased vibration especially under load. My car picked up a shudder at certain rev ranges when accelerating under load. With the shudder under load also a smell of toasting rubber.
My mechanic I work with feels it is also the crank pulley. He doesn't want to pull it to check as he says normally when they come apart they are in pieces. So, I'm putting in a new crank pulley.
I just put in a new belt tensioner and belt and I feel that is why I'm now picking up the vibration more. The old belt tensioner assembly was pretty shot.
Old Aug 31, 2014 | 06:48 AM
bavmotors's Avatar
bavmotors
Originally Posted by fastzombie
I am going to replace my crank pulley with an ATI Crank Pulley from Way Motor Works. I have heard and read that the stock pulley can begin to have the interior rubber come apart that leads to increased vibration especially under load. My car picked up a shudder at certain rev ranges when accelerating under load. With the shudder under load also a smell of toasting rubber. My mechanic I work with feels it is also the crank pulley. He doesn't want to pull it to check as he says normally when they come apart they are in pieces. So, I'm putting in a new crank pulley. I just put in a new belt tensioner and belt and I feel that is why I'm now picking up the vibration more. The old belt tensioner assembly was pretty shot.
Definitely sounds like the crank pulley
Old Aug 31, 2014 | 10:35 PM
Rusty8062's Avatar
Rusty8062
I also have the same vibration around 2-3000 rpms then it goes away. I've been told replacing crank pulleys with aftermarket ones will cause engine failure over time and to just replace it with a new oem stock crank pulley. Anyone have some input on this? Looking to replace mine soon as well as the dampener.
Old Sep 1, 2014 | 06:06 AM
fastzombie's Avatar
fastzombie
I believe it is safe to replace the OEM unit with a dampened crank pulley that combats the inherent vibrations from the crank assembly and engine. You do not want to replace the OEM with a solid lightweight pulley.
Way can add his thoughts and observations on this topic.
The ATI unit I am putting in is much better engineered than the OEM unit and is fully dampened.
I hope that helps.
Old Sep 1, 2014 | 06:10 AM
Rusty8062's Avatar
Rusty8062
I believe it is safe to replace the OEM unit with a dampened crank pulley that combats the inherent vibrations from the crank assembly and engine. You do not want to replace the OEM with a solid lightweight pulley. Way can add his thoughts and observations on this topic. The ATI unit I am putting in is much better engineered than the OEM unit and is fully dampened. I hope that helps.
Yeah I was looking to getting the ATI one aswell...would still like to hear some more input on this topic though.
Old Sep 1, 2014 | 07:05 AM
fastzombie's Avatar
fastzombie
Way Motor Works has great feedback on this subject. He can provide info on the cars he has worked on that have light weight non dampened crank pulleys.
You may want to search on the forum fro crank pulley.
Good luck with your search.
I have an ATI ordered from Way and will be installing soon. Dampened is the way to go. The ATI is a wonderful bit of engineering.
Old Jan 2, 2015 | 12:21 PM
jamfred774's Avatar
jamfred774
Not to steal your thread but I am having the same issues. 2-2400 rpm and you cannot see anything out of the rearview mirror. I purchased and installed the ATI balancer and it didnt see to help any...
elverado
Jan 18, 2022 02:51 AM
minieater
Oct 28, 2015 02:15 PM
barthayes
Oct 1, 2015 05:22 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
