Drivetrain How to remove aftermarket Crank Pulley
Old Aug 23, 2014 | 11:56 AM
IIIIIII's Avatar
IIIIIII
The previous owner of my car had installed a 2% m7 crank pulley, and I want to install an ATI but I cannot figure out how to remove the damn pulley.
Any help on this would be great.
Old Aug 29, 2014 | 02:11 PM
nkfry's Avatar
nkfry
Does the current M7 pulley have 3 tapped holes in a triangular pattern around the bolt flange? If so, you'll need the MINI crank pulley removal tool. If it doesn't have those tapped holes you will need a 3 jaw puller, but you will want to make sure the fingers on it are shallow enough to fit between the pulley and timing cover.
We rent the crank pulley puller out, as well as other required tools you'll need to do the job, as well as stock the ATI dampers.
http://www.detroittuned.com/crank-pulley-tool-rental/
http://www.detroittuned.com/mini-gen...r-tool-rental/
http://www.detroittuned.com/ati-super-damper/
Good luck, if you need anything feel free to PM me, or give us a call at the shop. 586-792-6464
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
mackedmini
Aug 20, 2015 02:35 AM
keck.j
Aug 18, 2015 08:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
