R52 Please Help Mini Cooper lighting problem
Old Aug 22, 2014 | 08:39 AM
mrmark990's Avatar
mrmark990
I have a 2005 Mini Cooper conv, both rear brake lights aren't , none of my passenger side indicators work and neither does my front driver side low beam. The indicator flasher in dash works normal though and doesn't flash quick like I'd expect it too? Any ideas any one???
Old Aug 22, 2014 | 11:15 AM
ZippyNH's Avatar
ZippyNH
Either a bcm (body control module) or a fuse panel (corrosion) issue.....
Both get wet...and cause issues...
Old Aug 22, 2014 | 11:19 AM
mrmark990's Avatar
mrmark990
is there way to determine which one it might be
Old Aug 22, 2014 | 12:03 PM
+1 For the BCM , you will have to pull it out of the kick panel.
If the top was down or leaked and they got enough rain and wet. That's points to either one. The BCM needs inspected itself and at the connections. If the connections are ok and the BCM has water sometime it can be dried out, if really bad it will need replaced.
Fuse panel is on the driver side kick panel in the footwell.
http://www.ecstuning.com/Search/SiteSearch/61356982115/
Thanks and good luck.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
