:: ECS Tuning :: MINI Door Brakes || Forge Alloy Tank || *NEW ECS Wheels Spacer Kits
Old Aug 19, 2014 | 10:46 AM
R55/R56/R57 MINI Door Brake Kit
Clicking or sticking doors are typically the result of a failed or worn door brake.
ECS offers genuine MINI Front Door Brake replacements, giving your R55/R56/R57 MINI Cooper a factory feel when opening and shutting your front doors.
The door brake attaches to the side of the door jam and mounts inside the front of the door.
Driver and passenger side doors use the same unit, with one door brake required per side.
The Simple Solution
Fits:
R55 MINI Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for MINI Door Brake kits
MINI R50 R53 Wood Dash Kit
This wood dash pattern for the five piece dash adds a little classic Mini tradition to your MINI. Dash is in plastic with high gloss burl wood pattern.
This addition is easy to install and matches other wood accessories. Snaps right into dash once old section is removed. Airbag section is just the cover and tether mount.
This kit comes with left small section, drivers section, center section, air bag cover section, and right small section to complete the 5 piece wood dash look.
Old school class & elegance
Fits:
R50 MINI Cooper (2002-7/2004)
R53 MINI Cooper S / JCW (2002-7/2004)
Click HERE for the ECS MINI Wood Dash Kit
R52/R53 Supercharged MINI Forge Alloy Coolant Tank
Forge is now offering a stunning coolant tank replacement for the R52/R53 supercharged MINI engines.
The polished alloy tank is a direct-fit replacement for the factory unit, and completely resists the cracking and fading of the original part.
The alloy coolant tank also adds a high-performance, premium look to your engine bay.
A Clever Upgrade
Fits:
R53 Supercharged MINI Cooper S / JCW (2002-2006)
R52 Supercharged MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for Forge Alloy Coolant Tank .
MINI R61 Paceman ECS Exact-Fit Stainless Brake Lines
ECS Exact-Fit stainless reinforced brake lines provide more confident and dependable stopping by maintaining consistent brake pressure, long lasting corrosion resistance, and increased protection from failure.
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Stopping never looked so good.
Fits:
R61 MINI Paceman (2013+)
R61 MINI Paceman S (2013+)
R61 MINI Paceman SX (ALL4)(2013+)
R61 MINI Paceman JCW (2013+)
Click HERE for ECS Brake Line Kits or for more information.
MINI R50/R52/R53 25/30mm Wheel Spacers
Don't let conventional spacer options leave you feeling down and out. ECS bolt-on wheel spacers are the right way to push your wheels out to the fenders.
These precision machined, 6061-T6 anodized black aluminum spacers have 4140 integral steel threads. Forget the perils of extra-long wheel bolts; these come complete with all the low profile bolts needed to properly torque the spacers to the hub in factory looking black and your wheels to the spacers.
ECS bolt-on spacers will have your car sitting just wide.
Space Out.
Fits:
R50 MINI Cooper (2002-7/2006)
R52 MINI Cooper Convertible / S / JCW(2005-7/2006)
R53 MINI Cooper S / JCW (2002-7/2006)
Click HERE for ECS 25mm and 30mm spacers kits.
MINI GEN2 R55-R59 25/30mm Wheel Spacers
Space Out
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R58 MINI Cooper Coupe' /S/JCW (2012+)
R59 MINI Cooper Roadster /S/JCW (2012+
Click HERE for the ECS 25mm and 30mm spacer kits
Aug 7, 2015 07:12 AM
Aug 7, 2015 07:11 AM
M7Speed
Aug 6, 2015 01:48 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
