:: ECS Tuning :: MINI R61 Paceman GEOMET® Brake Rotors
ECS GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits for better braking, select a slotted ECS GEOMET® rotor. Slotting cleans the pads by moving water, gasses, and contaminants away from the pad/rotor contact surface.
To prevent rust pitting and corrosion damage, ECS GEOMET® rotors are sprayed with a special water-based solution, then heated to cure the coating and remove all oil residue remaining from the manufacturing process.
Prevent rust pitting and corrosion damage.
Fits:
R61 MINI Paceman Base (2013+)
Click HERE for the ECS Geomets
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
