FS:: Didn't take long.... SOLD!!!!!
Old Aug 4, 2014 | 08:26 AM
OCVeloman's Avatar
OCVeloman
Category: Suspension
Price: $150
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58
Location (Region): SoCal
Item Condition: Brand New
Brand new Rear Control Arms / Camber Links I bought from the "Donald the Bonald" seller on eBay. Never got around to lowering the mini so these sat on my workbench until i sold the car. They're the dual heim joint arms with mis-alignment spacers on each bearing for stock fitment and boots to prevent joint corrosion. They're currently setup by the manufacturer for stock height.
I paid $180 shipped, Asking $150 shipped.
Stock pictures from his eBay listing (my arms are still wrapped in the box from him):
His eBay description:
Adjustable pair of rear control arm links with protective rod-end boots for Mini Cooper 2002-2012
In Matte Black Powder Coat
These arms are constructed of 1 inch (25.4mm) diameter x .095 inch (2.4mm) wall steel tubing. .
Each arm has a RH and LH thread precision rod-end bearing and lock-nut to provide easy adjustment. The arms are pre-adjusted to factory length, but can be shortened or extended to provide the rear wheel camber you want. The threads have been pre-treated with anti-seize compound to insure easy adjustability in the future.
The rod-ends bearings are nylon-composite-lined to assure good self-lubrication and should be maintenance free. With the boots and the pre-applied grease, future lubrication, except in the most severe conditions, should not be needed, but can be done if necessary. These rod ends are rated slightly in excess of 27,000lbs static radial load.
The rod-end boots are a tough, flexible neoprene rubber. They are resistant to gasoline and most oils and greases. The boots come pre-installed and pre-packed with a high load, water-resistant moly grease. And they are replaceable should they get damaged at some future time.
Due to design of the Mini, you can use these in either the upper or lower position, or both. If only installing one set, most people usually replace the factory lower arms. This enables you to adjust camber only. Installing these in both positions will enable adjustment of camber and track of the rear wheels. If your Mini is equipped with self leveling Xenon headlights, you may want to consider our sensor arm attachment. This is mounted on the upper drivers side arm.
Even if you leave these arms at the factory settings, you will notice a difference when aggressively cornering. The rod ends, while self-aligning have the added benefit of having no give, unlike the factory rubber bushings. They are about one pound lighter than the factory arms.
Easy to install. It takes about an hour per set, needing only common hand tools and the appropriate jacks. Instructions are included.
The factory center-to-center hole distance is 532mm, or about 20 15/16 inches. The maximum recommended length on these arms is 551mm, or about 21 11/16 inches.
Made in and shipped from the USA.
Old Aug 4, 2014 | 09:22 AM
OCVeloman's Avatar
OCVeloman
ej
Sep 28, 2015 05:41 AM
Grizld700
Sep 25, 2015 10:42 AM
MAGICIAN
Sep 1, 2015 05:04 PM
StuRat
Aug 24, 2015 06:24 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
