R50/53 Possible Belt Tensioner going bad?
Old Jun 30, 2014 | 08:00 PM
narvarr's Avatar
narvarr
Hello, I have an '06 6 speed manual MCS that I bought about 3 weeks ago with 78k on it. I must say I LOVE driving this car! But, my question is, how can you tell if the tensioner is going bad? The last couple days I've driven it I get the slight hint of burning rubber if I'm on it past 5k on the tach or down shift while passing slower cars. Is this a sign of belt slippage due to the tensioner weakening or is it something else?
Old Jun 30, 2014 | 08:40 PM
hypnotiqphil's Avatar
hypnotiqphil
make sure you check your crank pulley too, if you pull your passenger wheel off and take the plastic trim, see if you can pull on it if there is any play its about to blow up. and i mean blow up. happened to me was not a pretty sight
Old Jun 30, 2014 | 09:35 PM
minsanity's Avatar
minsanity
Burnt rubber smell often points to what phil said: CRANK PULLEY. Go ATI Super Damper.
Old Jun 30, 2014 | 09:50 PM
narvarr's Avatar
narvarr
Good to know. Looks like I need to find some info on changing it out. I've seen the posts about the ATI pully. Will it be more reliable than the factory?
Old Jul 1, 2014 | 02:52 AM
Kahnfucious's Avatar
Kahnfucious
That's not burning rubber that's your car running rich..as it is designed to do. Every mini when you get on it smells a little.... Mine does it all the time. You are fine... It's the cars way of avoiding damage from a lean condition.
If you want to check it...pull off the passenger wheel release the tension on the belt and tug on the pulley...but the crank pulley exploding will throw codes and lights.
Old Jul 1, 2014 | 05:01 AM
IQRaceworks's Avatar
IQRaceworks
When my belt tensioner started going bad, I could watch it bounce around on the belt when the motor was idling. With the new tensioner...no bouncing.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
Sep 8, 2015 11:37 AM
