R50/53 boost gauge instal
Old Jun 18, 2014 | 07:24 AM
Saltysalt's Avatar
Saltysalt
boost gauge instal
Heya fellas
so i installed my boost gauge last week, and reinstalled it last night since i didnt have long enough vacume hose, and it was thin walled so it was easilly crimped, got some new stuff, way more rugged
but im seeing 10-11 psi when i pull, havent put my foot to the floor above 3.5k rpm yet, hasnt been that long, but i figured i should still see around 15 psi even at low rpm
it isnt a stock pulley, but i have no confirmation of what pulley it is, was there an aftermarket 12% or stock? unless i have a boost leak somewhere
i am reading around -15 at idle, and ussually around -23 to -25 coasting in neutral, so this seems normal to me
the thing that gets me is when the car is off its at 0, but if i freshly turn it off it takes about 30 sec to go from 10 vacuum to 0, is that normal?
also my ultra gauge says 15-16 psi where the analog is 10 and the vacuum is ussually 5-8 higher on the ultraguage than the analog
im just confused!
Old Jun 19, 2014 | 09:15 AM
Jones424's Avatar
Jones424
the only time I see 15 is WOT approaching redline
im not sure about the gauges showing differently but your saying 5 higher our cars stock even with pulley will not reach 20.
did you hook up off the fuel pressure off the port of the supercharger?
silence2-38554
98
Sep 21, 2016 02:52 PM
wkp1219
Nov 13, 2015 07:52 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
